Question about Traeger Industries BBQ070 All-in-One Grill / Smoker
Traeger BBQ trips circuit breaker
My traeger BBQ after running for more than just a couple of mins. will trip the GFI and circuit breaker. It has not done this in the 4 years that I have owned it and has been plugged into the same outlet the whole time. I replaced the outlet and the GFI, it still does it. I can plug anything into this out let and it will work with the exception of the traeger. Is there a fuse or something I need to look at in the trager itself?
  • Anonymous May 11, 2009
    sane problem on a brand new grill-I'm sure our problem is the fan motor as the fan doesn't run freely-we are sincerely disappointed in what we thought to be a quality product
Mine is doing the same thing, but it does it within seconds of turning it on. I'd assume you as well have the digital thermostat. I've narrowed it down to what I believe is the flame ignitor (or the purple connector). Unplug it and it should eliminate tripping and order new part or get warranty part.
Posted on Apr 12, 2009
My two friends and I bought new Traeger's in December of 2009 and within 45 days began to trip the GFI for all 3 units. I am an electrician and did some tests to find the igniter is shorted to its case. This is a dangerous electrical condition and could result in electrocution if you bypass the GFI for a regular outlet. I have replaced the two igniters for my two friends and the problem has gone away. Mine is still failed and I am waiting for a replacement. While talking with Traeger representative, he stated they had some bad igniters installed and are replacing with a better quality unit. Good luck in your efforts
Posted on Feb 14, 2010
    New Friend:
I had the same problem. Replacing the igniter rod did indeed fix the issue. I followed this helpful video which made the process very straightforward:
http://www.youtube.com/watch?v=MELAQbssL0g
Posted on Dec 01, 2013
    New Friend:
Installed brand new igniter. Pops GFI. What a crock of cra p this product is. After owning this for 4 years, it has been something every single year. Some guys get lucky, most guys get a lump of s***.
Posted on Apr 16, 2017
I have been using my Traeger for ~ 4 years and it has been fine until recently when it started poping the GFI. I tore the whole thing apart and realized it was the auger. Due to the rainy weather the dust from the pellets had turned into glue and clogged the auger. After I cleaned it out and put it back together, I turned it on and realized I had burned out the ignitor while troubleshooting it. I replaced it and it worked fine the next two times but then it started popping the GFI about 10 minutes into the warmup period. I was able to determine that it is not the GFI. Then it started working again for me so I stopped troubleshooting it. My wife tried using it a couple of days later and the GFI popped again. I'll try starting it with the igniter and then disconnecting it after the fire is started.
Posted on Jan 28, 2010
  • Joe Raponi
    Joe Raponi Nov 27, 2013
    I have the same issue with the GFI tripping. The unit works fine on a non GFI circuit.I called the Traeger rep and he said right away it is the igniter rod. Replacement of the rod should fix the problem
Louisiana BBQ grill trips circut breaker
You need to take other devices off that circuit. Also outdoor circuits usually are on a GFI circuit.which are very sensitive to flucuations.
Jul 14, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Nothing works, no fan, no auger
Sounds like no power. Is it plugged into a GFI circuit that might have tripped. On its website in the FAQs Traeger mentions that if pellets get wet, this can cause a GFI circuit to trip and they suggest a specific remedy. Check out their website at http://www.traegergrills.com/ and if necessary contact their service techs who can help you troubleshoot.
Mar 09, 2014 | Traeger Industries Grilling
Treager bbq keeps tripping breakers
I would strongly recommend you pull the control panel and inspect the fuse. Before tripping a breaker, your GFS outlet should trip, and/or blow the fuse.
If the unit is tripping circuits, then there is likely a short. Given the material draw from the hot rod, I would start with that. Putting a multi-meter on it to test voltage, should give you a basis to confirm with Treager if it's within spec. Sometimes it's simpler to replace the rod, but this can add up quickly if not the root issue.
Dec 26, 2013 | Traeger Industries Grilling
Federal pacific breaker that has not tripped but no power in circuit.
I have run into 2 over the years that had "GLAZED" contacts. Will read voltage good but no amperage to run anything. Try replaceing it.
Dec 13, 2013 | Federal Industries Federal Pacific 20Amp...
Home fuse box breaker issue
Hi Rex,
It sounds as if the upstairs bathroom outlet and the outdoor outlet are on the same circuit. There's a very good chance that these are GFI or "ground fault interrupter" type outlets, as these locations (and others) have required this type of protection for over 30 years. It was a common practice to run a circuit from the panel to one of these locations (or another) and then run from here to the next outlet and then on to the next. Since the GFI outlet could be purchased for around $10 instead of $30 for a GFI breaker, electricians would install outlets instead - both offered the same protection. A "regular" breaker would supply power to this circuit - but the very first outlet would get a GFI type outlet. It would be wired to the LINE terminals and the cable that feeds the rest of the outlets on this circuit would be connected to the LOAD terminals. If there was a ground fault condition, this GFI outlet would trip, but the circuit breaker would remain on. You would locate and RESET the tripped GFI outlet to restore power. The only time the circuit breaker would trip is if the circuit was overloaded. Overloads would NOT cause the GFI outlet to trip.
Now that you understand how it was typically wired years ago (and still a lot of times today), you should check all the outlets outside your home, in bathrooms, basements, garages, and inside your home next to doorways that lead directly to grade of your lawn or deck. These are required places for GFI protection. Press the RESET on any tripped GFI outlet to restore power. If the outlet will not RESET, there is a condition where the hot wire (black, red or blue insulated wire) is in contact with ground, or a device or appliance connected to the circuit has a problem. Unplug anything connected to the circuit and attempt to RESET again. If still unable to reset, open the outdoor outlet again and carefully pull it out and away from the box. Inspected for damaged or crushed insulation and repair / tape as needed. Before reinstalling, try to reset again. If it holds, trip the GFI by pressing TEST button. The RESET button should pop out. Reinstall the outlet and make sure the wires are not crushed or cut. Press the RESET button again. If it trips, you will have to remove the outlet again and take more precautions against damage to the insulation. it is also possible that the GFI outlet itself has failed, in which case it should be replaced.
GFI circuit breakers and outlets are supposed to be tested monthly by simply pressing the TEST button and then the RESET button. Replace any GFI device that does not test correctly if wiring and devices / appliances connected are OK.
I hope this helps & good luck! Please rate my reply - thanks.
Jan 05, 2012 | Hammering
My Sylvania - ground fault 15 amp breaker (32740) is tripping with minutes of reseting. It is for 3 washrooms & hallway & is 30 years old .....does or can it loose its life span? What is the cost...
A circuit breaker can go bad, but usually not in the way that you describe. That's not to say that it can't happen, but just not typical. GTE Sylvania breakers were once popular - I installed quite a few GTE / Sylvania electrical panels in homes in the late 80's. You may have trouble finding replacements; do not put an breaker that "fits" into the panel, unless the breaker is designed for use in the panel you have.
The first thing to do is determine the source of the problem. The breaker will trip, but not indicate if it was the result of a heavy electrical load or a ground fault condition. A 15 amp circuit breaker is designed to carry up to 12 amps continuously. The greater the load, the more quickly it will trip. it may carry a 14.5 amp load for several minutes to an hour before tripping, and a 20 amp load may be carried a second or two. GFI breakers are designed to carry 5 thousandths (.005) of an amp (or 5 milliamps) to ground, or the 12+ amps to neutral before they trip.
The way I would attack the problem is to install a new GFI outlet in front of the old wiring, by "inserting it" between the panel and the other plugs and lights, switches, etc on that circuit. The GFI outlet will provide the same GFI protection that the circuit breaker provided at a fraction of the cost.
Turn off the old GFI breaker, and remove it completely. Install a new, standard (non-GFI) single pole 15 amp circuit breaker in its place. Completely remove from the panel the cable that the old GFI breaker fed. Buy a new electrical outlet box (surface or flush mount as desired) that is large enough and deep enough for a GFI plug and 2 cables (if surface mount, use a 4" square deep box and appropriate cover - or if flush mounting use a deep plastic / fiber single gang box). It will be installed in a place close to the panel, but where the old cable will be able to reach inside. Bring the old cable removed from the panel into the new box. Run a new cable that has the same number and size wires from the panel into the new box, too. Connect the circuit neutral and circuit ground to the neutral and ground bars in the panel (they are probably the same bar) and the hot wire to the circuit breaker. make sure that the circuit breaker is OFF. Twist the two ground wires together and combine an 8 inch length of bare or green insulated wire with them in a wirenut.
Next, wire a new GFI plug in the new box. Connect the green wire from the wirenut to the green terminal of the GFI outlet.
Connect the plug's LINE terminals to the neutral and hot wires in the cable that you ran from the panel to the outlet box.
Now, connect the GFI plug's LOAD terminals to the neutral and hot wires in the cable that you removed from the panel and reinstalled into the new outlet box.
Secure the GFI outlet into the box and install the cover. Cover the electrical panel.
Power up and test. if the GFI trips, there's a ground fault in the circuit. If the circuit breaker trips, the circuit is overloaded.
Jun 13, 2011 | Your One Source Qo Single Pole Ground...
The pump keeps tripping the GFI. We have cleaned
How long have you had this pump? Have you had it long enough for the bushings and bearings to go bad. Have you added anything else to that line that feeds the breaker. that feeds this pump If you tell me thies things i can give you a much better awnser
Aug 08, 2009 | Savio Water Master Solids Handling Pond...
Fridge keeps tripping the circuit breaker
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Mar 01, 2009 | Refrigerators
LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Jan 02, 2009 | LG WM2016C
15 amp Gould breaker trips every 24 to 48 hours
As seemingly with everything else, these devices were once very reliable but now fail early in life.
Assuming that this is no GFI (Ground Fault Interrupter) equipped breaker, you must  have a bad one. If it is, you may have some stray currents tripping the breaker.
While finishing up on our new home and putting breakers in the main box for the first time, one brand new breaker refused to stay set even though the circuit was OK and no loads on that branch connected at all. In the two years we have been here, we had to replace a second one acting just as you describe.
Dec 15, 2008 | Ace Hardware Hi-Tech Circuit Detective...
Traeger Industries BBQ070 All-in-One Grill / Smoker Logo
9,392 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
