Question about Dishwashers
Problems Keeping the cycle going
Bosch dishwasher, Ascenta SHE4AM1. I start any cycle("active" light is lit). I hear a quiet whirring as it starts up. Then the spraying starts, but only lasts 5-10 seconds and then quits. The "active" light goes out and the "clean" light comes on. Then it sits silently until I turn it off.
Things I have tried:
1. Ran the hot water tap in the sink nearby. It took 4 tries, but the cycle held and ran for the prescribed length of time. The "active" light went out and the "clean" came on and it sat silently for most of the night. When I finally openned the door, there was water in the bottom (about 1 inch).
2. Tried all the cycles, same behavior for each , "active" light on, cycle started, after about a minute or so, spraying stopped and "clean" light came on. Cycle seemed to end - washer became silent and sat with the "clean" light on).
3. Made sure water supply was turned on. It was.
  • rlsfdo Jan 20, 2009
    There is no selector swith on the front of the Bosch Ascenta SHE4AM1. Maybe there is a component with a similar purpose? Or there is a recovery code which can be set becuase the washer is wating for the pass-throuigh heater to get the water in the input line hot enough?
    Sergeant:
  • 227 Answers
On the back of the selector switch there is a timer motor or clock motor assembly. The gears wear out or the motor has lost its ability to go through the cycles. Replace it and you should be fine.
Posted on Jan 17, 2009
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Bosch dishwasher door pops open during cycle
Latch needs adjustment or replacement.
Jul 07, 2015 | Bosch Dishwashers
My bosch dishwasher is stuck on a cycle, it keeps on flashing and won't start
try shutting off the power at the breaker panel and wait a minute sometimes rebooting will clear up a problem
Oct 27, 2014 | Bosch SHE6AP15UC Ascenta Evolution Series...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
SHE45M05UC
the problem is the float switch is stuck
Dec 11, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
669 people viewed this question
Top Dishwashers Experts
