Removing partial install of 2nd os
I have a computer with XP Home that I started to upgrade to XP Pro. During the install something happened to the cd drive and it stopped reading the disk. Now when the computer restarts I get a screen asking which os I want to use XP Home or XP Pro Setup. At this point I just want to remove the XP Pro Setup since my cd drive no longer works. How can I do that?
  • 5 more comments
  • mannybobanni Jan 16, 2009
    The system restore won't allow me to go back far enough to the date of install. Now what?
  • mannybobanni Jan 17, 2009
    It's an HP laptop, so I think it might be expensive to replace. I never priced it, but it might not be worth fixing. Is there anything else I can do, or am I just stuck with the setup being partially completed? I'm guessing there are files out there somewhere that are telling the pc to try and complete the setup. Is it possible to just delete those files and fix the problem? I'm sure it's not that simple, but any other help would be appreciated.
    It's a Pavillion XH555 prod# F3929HR sn#TW14029307. It's probably about 7-8 years old, or more.
    Yes I can, as I tried that per earlier instructions.
  • mannybobanni Jan 18, 2009
    I uninstalled and reinstalled the cd/dvd drive but nothing changed in the way it operates. I pretty sure there is a problem with the physical drive and not the driver or installation. I can here the drive spin slow and the read/write head move and click, but the drive never spins fast as in normal operation.
    So aside from having a new drive installed is there anyway to get rid of the partial XP install, or for that matter completely reinstall the system from scratch, without having access to the cd drive?
    Will the pc boot from an external cd drives, or does Windows have to load drivers before they will work. I'd really like to reformat the HD and start a new install from scratch, but if the pc won't boot from an external device then I can't do that.
    I really appreciate all of your help, Spoem. Keep up the great advice!
  • 202 Answers
You should be able to do a SYSTEM RESTORE to a point before the XP Pro installation.
Start the machine and start tapping the F8 key until the boot menu is displayed. Use the arrow keys to highlight SAFE MODE and press enter. If you are given a menu to choose which Windows to boot into, choose the Home edition. Windows will load with the minimum drivers. Your screen display will be 640 X 480 and the icons will be large. You will eventually see a window advising you that you are in safe mode, click OK or NO. Click NO. That should open The System Restore function. Choose to restore the system to an earlier date. A calendar with be displayed. The BOLD dates are the ones that you can restore to. Choose a date that was before the date you tried to install XP Pro. Follow the prompts and the restore process will run and reboot your computer. Following the reboot, the installation will complete and Windows will open.
If you have installed a service packs or updates after the restore date you will need to install them again.
Good Luck! and please let me know how this works out for you.
Posted on Jan 16, 2009
  • 5 more comments
  • Barry Parks Jan 17, 2009
    What kind of computer is it? Desktop or laptop? Can the CD-ROM be easily replaced?
    What is the model? I'll try to see if the drives are swapable.
    Can you boot into Safe Mode?
    Boot it into Safe Mode. Right click on My Computer and then click on MANAGE. In the left column, click on Device manager. In the right window you should see all of the installed devices. Look near the top to see if the CD-ROM is shown. If it is, right click on it and choose uninstall. If you are prompted that the device will be uninstalled click yes. The drive should then be uninstalled.
    At the top of the window is My Computer. Right click on it and then click on "scan for hardware changes". The drive will hopefully be reinstalled. After the installation completes, close everything so you are back to the desktop. Put a CD in the drive and test to see if you can explore the disc.
    Let me know what happens.
  • Barry Parks Jan 18, 2009
    Thsi would be a long shot, but worth a try. Do you have access to a different computer and , if so, do you have a 1 GB or larger USB thumb drive? If you can use these two, copy the entire XP installation CD to a folder on the thumb drive. There are probably some hidden files on the CD, so you will need to make them visible before you copy the files. Then see if you can access the USB folder from your computer. Run setup and press enter to install XP. At the second menu, press 'r' to repair an installation of XP. Choose your Home installation and follow the prompts. With a little luck, it should work.
    Another option would be to check used computer stores for an external CD-ROM drive. Some of them connect to the parrallel port. If you can find one, this would be a good option, as you would have a drive in the future. It has been a while since I've seen these, but it's an option, if you can find one.
    Here's an option that may save you some effort. I checked on ebay and found an external drive that connect trough the pcmcia slot. There are also so usb 2.0 drives for less, but I don't know if they would work, as I think your laptop is too old and has usb 1 or 1.1. Anyway here's the link:
    http://cgi.ebay.com/24X-EXTERNAL-LAPTOP-...|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50
    As always, good luck!
    You would need to check the BIOS to set the boot order. You should be able to tell by the available options. Some devices, like USB, will only show if they are connected.
How to reinstall windows xp thinkpad x41
How to Reload Windows XP Without Removing Files Deleting system files, modifying the registry and installing incompatible drivers to Windows XP can damage the integrity of the operating system, rendering it inoperable. Virus infections are often responsible for making the aforementioned changes to a system, but employees who have administrative access to the workstation can make deleterious modifications to the OS as well. Reinstalling Windows XP can repair the OS, but if work-related files are stored to the system partition, all of the data will be erased during the installation process. To reload Windows XP without losing files, you can perform an in-place upgrade, also known as a repair installation.
Step 1
Insert the Windows XP CD into the optical drive and then press "Ctrl-Alt-Del" to restart the computer. Step 2Press any key when prompted to load the contents of the disc. Press "Enter" on the Welcome to Setup screen.
Step 3 Read the license agreement, pressing "PgDn" to scroll down the page. Press "F8" to agree to the terms. The CD will search for previous installations of Windows XP. Step 4
Press "R" to repair the selected operating system. The disc will begin reinstalling the operating system to the hard drive without affecting personal files. Follow the on-screen prompts to complete the repair installation. Step 5
Log in to Windows XP and sign on to the Internet when installation completes. Click "Start," "All Programs" and then "Windows Update." Step 6
Click "Scan for Updates" to search for applicable service packs and hotfixes to reinstall to the OS. Step 7
Click "Install Now" to bring the in-place upgrade up-to-date.
Things Needed
  • Windows XP CD
Tip
  • Make sure you have your Windows XP product key (found on the CD cover or on the computer case) available prior to reinstallation.
Warnings
  • If possible, back up your files previous to the installation in case something goes awry during the process.
  • You will need to reinstall all non-native programs and removable devices after performing an in-place upgrade.
Apr 27, 2014 | Lenovo ThinkPad X41 Tablet PC
I have a computer, with microsot xp home edition service pack 3 system model KM400-8235 total physical memory, 1,280,00MB available 428,91 gb total virtual memory 2.0 gb available 1.96 gb page file...
If you boot from the Windows CD you should have the option to Format the Disk. Since you are using an Upgrade you will need to format the disk and install the Original OS then do the upgrade again.
Sep 28, 2011 | StarTech.com StarView SV211K 2-port KVM...
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
OS - windows home edition to windows XP - upgrade?
Home Edition is already a version of XP. XP was released in Home and Professional versions. You can find out for sure what version of software you have by right-clicking on the desktop icon for "My Computer" (or on the "My Computer" entry on the Start Menu if the icon is not on your desktop), then clicking on "Properties" from the popup menu.
If you want to upgrade from XP Home to XP Professional, you can do that with the appropriate upgrade CD. But unless you are networking in an office setting, there really are no features in Pro that you don't have in Home.
If you still have questions, please post a follow up comment and I will try to help further.
Mar 31, 2009 | Dell Latitude D600 Notebook
Can't load xp pro onto my IBM Lenovo M52 Desktop
Check to see if the CD is an upgrade. If so, load an older OS first and then use the CD to upgrade.
Dec 11, 2008 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
OS Matter
Nope.
Without the disk you cannot upgrade to Windows XP Pro, because both Windows XP Home and Windows XP Professional are two different edition / version.
So if you want to upgrade your current operating system from Windows XP Home then you have to spend money to buy Windows XP Pro
But if you want to upgrade the Service Pack then you can very well do it.
Click the link below to download Windows XP SP3 for your edition and install it. Before installing it make sure you have turned off your security programs or better install it from the SafeMode
http://www.microsoft.com/downloads/details.aspx?FamilyID=5b33b5a8-5e76-401f-be08-1e1555d4f3d4&displaylang=en
Good Luck
Jun 17, 2008 | Microsoft Windows XP Professional With...
Un-Install XP PRO Upgrade
When you installed the upgrade, if you chose not to save the needed files for later uninstalling, you may not be able to uninstall. Check the Add/Remove Programs in Control Panel. If the upgrade is listed, removing the upgrade should put you back to where you started. If not, you would have to do a full system restore from a full system backup (which hopefully you have), or backup your data files and then do a clean installation of the prior OS.
Apr 19, 2008 | Microsoft Windows XP Professional for PC
Hdd upgrade problem
Try reversing the connections so the new drive is detected as the primary master.
Oct 07, 2007 | Gigabyte GA-7VTX Motherboard
Computers & Internet Logo
198 people viewed this question
David Payne
David Payne
