Question about RCA RS2640 CD Shelf System
Buzzing noise My audio system recently started making a constant buzzing noise out of the speakers. When I turn the radio on or the cd player on, I still just get the buzzing noise. When I disconnect the speaker wires or hit mute, the noise stops. Reconnect the wires or turn off the mute and the buzz returns. I have unplugged the power cord to reset the system, but that didn't help. I have check out many forums for help with this problem and it sounds like this is a power supply problem. What do you think? If you have a resolution, can you help me figure out if it is worth fixing based on the repair cost? We paid about $150 to $200 for it. Thanks for any advice you can give me. David Dempsey
  • Anonymous Apr 20, 2008
    JUST PURCHASED AT A YARD SALE, CONNECTED IT AND THERE ARE ISSUES. IT PLAYS BUT SKIPS, STOPS, BUZZES ON SOME CDS, DOES NOT PLAY OTHERS. THERE ARE NO RETURNS UNDER THE CIRCUMSTANCES, BUT I LIKED THE UNIT. IS IT REPAIRABLE? IS IT WORTH REPAIRING, OR AM I JUST STUCK WITH A FAULTY UNIT. I WOULD APPRECIATE YOUR INPUT.
Of course it will stop buzzing when you mute the speakers. From the limited description, it could be anything from a power supply to loose wires in the system between the speaker leads and the motherboard. Best bet is to take it in to a technician and get a pro's answer. If he wants to charge more than what it's worth to you, get a new one.
Posted on Jun 19, 2007
  • 3 Answers
I had the same problem with mine and the fix for it was to replace Q401 transistor on the main board. I used a NTE382
replacement and it has worked fine ever since.
Hope this helps
Posted on Nov 17, 2007
SOURCE:
Realistic STA-2150 Receiver - Making buzzing noise through speakers
The problem may go away when the turntable ground wire is disconnected from the receiver.
Jun 26, 2017 | The Audio Players & Recorders
Why Is my RCA home theater system making that noise through the speakers it's like a buzzing noise
It sounds like you are getting bleed through from another device...radio, cd player...etc. This is caused by improper grounding. Some where there is a wire not connected correctly or you need to ground the whole system.
Jan 30, 2013 | Audio Players & Recorders
Kenwood KVT-815DVD Unit only buzzes
I bought a Kenwood KVT-815dvd player and got everything hooked up to only find out that it had a security code. The problem now is that I got it from a pawn store and they did not even know that it had a security code on it. So is their a way I can bypass they password or just reset the whole unit so that it does not have one. Also, where is the memory for this unit?
Thank you
Nov 19, 2009 | Kenwood Excelon KVT815DVD Car DVD Player
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
Buzzing emitted by vsx-409
Could be the result of having DTS compatible equipment connected through the analog inputs on the VSX-409D. Noise and distortion will result as essentially the DTS signal is being played back undecoded. If this is the case you'll have to connect your LD or CD player through the digital connections (coax or optical) and set 'Signal Select' (button on front) to 'Digital'.
Jan 06, 2008 | Pioneer VSX-D409
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Buzzing noise
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. I used a NTE382
replacement and has worked fine ever since.
Hope this helps
Aug 26, 2007 | RCA RS2640 CD Shelf System
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Sep 01, 2006 | Cambridge Soundworks BassCube 12 Speaker
Something spinning
1. Check all cable connections to make sure they're secure. 2. Replace the cable connecting the CD unit to your receiver. 3. Clean the contacts on the player and receiver with electronics-grade contact cleaner. good luck
Jan 06, 2006 | RCA RS2041 CD Shelf System
RCA RS2640 CD Shelf System Logo
620 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
