Question about Kenmore 46462 Front Load Washer
I have an elite he2 plus frontloading kenmore washing machine and no water is coming in the washer.... the temperature has been low here, but i have taken every precaution to ensure that my pipes aren't frozen.... i have running water in my house... my washer and dryer are in a laundry room in my carport....(the laundry room is enclosed and i do have a heater running in there)
  • 15,935 Answers
Only if your temperature in your area goes below 35 degreesF.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
What does error code f5 mean?
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
You most likely have a loose connection at the tub sensor , or a bad heater.
Read more: http://forum.appliancepartspros.com/washer-repair/244131-error-code-f5-model-11045087404-kenmore-elite-residential-washer.html#ixzz34ySdUUeZ
Jun 14, 2014 | Kenmore HE2 Plus Front Load Washer
Corrosion frontloader kenmore
washer Corrosion Near bottom door and around the circle
Feb 19, 2014 | Kenmore HE2 Plus Front Load Washer
Check the water temperature sensor on a kenmore he2 plus washer
I am having the same problem, one wire broke off from the plug. Can this plug be fixed or will I have to buy a new wire?
Oct 29, 2012 | Kenmore HE2 Plus Front Load Washer
My HE2 frontload washer will ot unlock hepl!!
Hi.... you have something in your drain pump or your pump is bad... if it locked you out
Mar 25, 2011 | Kenmore HE2 Plus Front Load Washer
Remove the front panel of Kenmore Elite Frontloading washer
You gotta tip it back to get to them screws on bottom panel64cf6cd.jpgf596406.jpga6e1280.jpg
Mar 11, 2010 | Kenmore HE2 Plus Front Load Washer
Water is coming out of the area were you put the detergent. Hoses are all connected and seam to be in good condition.
I take it his is a frontload style washer. You probably have soap buildup underneath the detergent tray, where the soapy water enters the hose that goes to the tub. Try to remove the soap tray and clean the buildup.
Jan 12, 2010 | Kenmore HE2 Plus Front Load Washer
F21 on the Kenmore HE2 Plus Frontload Washer
there is a removable access panel on the front of the machine under the door. Remove one screw from each side. There you will find the pump that has a strainer basket on it. Remove that and clean the blockage out of there. You will also find attached to the panel, another manual that explains the codes better
Dec 27, 2009 | Kenmore HE2 Plus Front Load Washer
HE2-plus washer will not start. error, status light shows "F-24"
code F24
WATER TEMPERATURE SENSOR ERROR
sorry but the following information is for TECHNITION SERVICE(only)
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
"Was this helpful?"
May 10, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 46462 Front Load Washer Logo
80 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
