Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Riding mower dies when releasing brake
Mrfixit, i'm not sure what safety switch you're talking about
  • 138 Answers
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Posted on Aug 17, 2009
Engine dies when brake is released.
You have a problem with a safety interlock. I'm betting it's the operator presence safety seat switch. To check if it is the seat switch:
  1. Unplug the seat switch.
  2. Jumper the seat switch wiring harness plug receptacles.
  3. Start your tractor & release the brake. If the tractor stays running, replace the seat switch.
Sep 25, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Where is the part located that shuts the mower off when you release the clutch
There is a safety switch for the brake clutch and if the seat safety switch is not activated by someone sitting on it, then the mower will die. So if you are sitting in the seat and the brake clutch is released and the seat safety is faulty then the engine dies, so the seat safety is where you should start looking.
Aug 31, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Replace switches & clutch. When brake is release everything dies. Ineed a wiring diagram.
There are a few safety switches on a riding mower. One is the brake clutch, which must be engaged to start mower if not in neutral for a manual transaxle. Another is a blade engaged safety that will not allow you to start it with the blades engaged and the other is the seat safety that prevents starting if the brake is not engaged.
If the seat safety switch is messed up and you release the brake it will kill the engine. I would start there.
I hope this helps get you going.
Aug 03, 2011 | Garden
I have a 1 yr. ferris mower 2000z 61'' It dies when apply brake.
IT COULD BE THE SEAT SWICH OR THE BRAKE SWICH
Sep 27, 2009 | Garden
Simplicity mower stalls when brake released
There is another safety switch connected to the parking/service brake. Check that one too. Sounds like its the one.
Jun 22, 2009 | Garden
Engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mar 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
127 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dwain Pippen
Jim Parker
Jim Parker
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
