When I try to get into my pictures on the computer a warning comes up 'Kodak EasyShare Not responding'. I have uninstalled and re-installed my software but im still getting this warning
I have had the same problem with my software and Vista. It seems to be common as well. Try this:
go to "download.com" and search for "paint.net". That is the software I use and it works great.
From the menu bar, select Help > About Kodak EasyShare software.
Note the software version. If you have Version 8.0 or later installed on your computer, review the help information for Transfer Pictures.
From the menu bar, select Help > Kodak EasyShare Help.When the Welcome to EasyShare Software window appears, select Transfer pictures, then read the help information.
If you do not have Version 8.0 or later installed on your computer, go to EASYSHARE Software Downloads, then follow the instructions to download the latest version of software. Approximate download time is 5 minutes for Cable/DSL, or 2 hours for a dial-up connection.
If that doesn't solve your problem you can manually add your pictures/videos to easyshare software.
In easyshare Software, select My Collection, then select Add Pictures. The Add Pictures screen appears.Look at the Select a location field. If the My Files folder is collapsed, click the + to open the folder.In the Select a location field, select your camera folder, for example: M381 Digital Camera. Thumbnails of the pictures/videos on your camera internal memory, and on a memory card if one is in your camera, appear.
Select the pictures/videos to add to EASY SHARE Software, then click Add Pictures. To add all the pictures/videos in the folder, click Add Entire Folder.Click Done.
one way or the other, someone must have change some settings on the Kodak EasyShare printer unknowing to you.
Since you do not know want was pressed to have caused this, the it would be better if you reset the printer. resetting will put the printer back to its default state. This will make the printer work fine as it has been doing before.
Or uninstall and reinstall the printer drivers. That is, detach the printer cord from your computer, uninstall the Kodak EasyShare printer dock Series 3 software, restart your computer and reinstall the software back just as you did when you first installed the printer to your computer.
With the cam connected , open the easyshare software ,bypass the transfer window then click on the ADD PICTURES icon on the top left,under SELECT A LOCATION click on the model no. of the cam. Tag all the pictures you would like to add, then click on ADD PICTURES. Click on DONE once finished.
The problem that you describe indicates that your Kodak EasyShare software has somehow become corrupted. Uninstall the software (use the uninstall feature, not just delete) then download and install the current software from the kodak.com web site (this is a no-cost download). That should cure the problem, but if it doesn't I suggest that you contact Kodak customer service via their web site.
The Kodak Easyshare software just index the pictures they do not store them at all you can locate the pictures on the computer by
Click start then look for search type in in the search box *jpg And it will display all the pictures that you have on your computer
To fix the problem regarding the easyshare software try uninstall it from your computer Then download the clear utility www.kodak.com/go/clear then download the latest version of the easyshare software www.kodak.com/go/easysharesw
I have upgraded my Easy share software to version 7.1 ever since I cannot open the program. It comes up with The message of "One or more system DLL's could not be loaded :ES App.dll " then appears the message of "Easyshare unable to run. Please run Setup and choose repair to fix the application.[0,5006,0] " . When I run the repair program, it blocks part way through and the error message of 1334x97x3839719742x appears. Short of getting rid of Kodak off my computer which I dont want to do as I have important pics in the album, and I have a Kodak digital camera. What can I do to fix.
Remove any Kodak Software.
Reboot the computer
Plug in the camera.
This should now be listed as an extra drive in 'My Computer' and/or The scanner/Camera Wizard Window will come up asking what action to take.
