Question about Canon imageCLASS D880 All-In-One Laser Printer
Jamming I just aquired a canon G3 D880. It has jamming issues and I need to reoplace the fuser assy. I need assistance in removing this assy in the proper manner. Manny
  • 71 Answers
Its a very big teardown to remove the fuser assembly
Posted on Jan 16, 2009
Solution to solve system Error E007 on IR 2016i copy machine
Was the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error.
error codad E007 First make sure fuser plastic not damage? Or not move the proper place? if damage fuser plastic Replace by new one if the fuser plastic not damage keep proper place.
fixing fuser film is worn out or broken remove the fixing unit ang check the fuser film if its worn out broken replace a new one .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Canon CLC 1140 Copier
Paper jam internal, can't access. accordian at exit tray
more the likely it is in the fuser unit of the copier .
May 04, 2010 | Canon ImageClass D880 Copier
Cannon image class D880 System Error E000
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
Jan 12, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
Nov 15, 2008 | Canon imageCLASS D880 All-In-One Laser...
Canon super g3 image class d880
E000 means your fuser section is having problems.sometimes you can reset but may need to replace fuser unit.
Sep 04, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Jammed paper
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Jun 07, 2008 | Canon ImageClass D880 Copier
Canon D880 fuser
With an offset #2 phillips screwdriver and some patience you can do this- we have been fixing PLENTY of fusers on the imageclass series-you can get the fuser out thru the exit side of the copier.
1. UNPLUG COPIER , pull platen to left with grey lever
2.remove one screw for upper plastic cover cover pulls down and out
3.remove 2 screws on lower exit cover this comes up and out
4.remove small plastic cover on left side of exit assembly as you face end of copier.
5.pull back black plastic sheet to expose 3 connectors one plugs into circuit board two plug into heater or fuser assembly. unplug these
6.with your offset driver remove 3 screws holding fuser to frame of copier -these will be pointing up.
7. lift fuser up and carefully work out of copier.
check for stuck papers or damaged fuser film sleeve.
To reseat fuser and replace panels go slow and easy the panels fit back in kinda funky it takes a bit of tinkering.
We do not turn the copier upside down to remove the fuser and have replaced about 20 of the fusers or installed a new fuser sleeve.
Good luck and ask all ya want if more assistance is required.
Apr 05, 2008 | Canon ImageClass D880 Copier
CANON d880 e000 eRROR
THE FUSER YOU REPLACED IT WITH WAS DEFECTIVE
Nov 15, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon PC-795
The blinking light with the squiggle symbol is the display for a paper jam. Not sure a service manual will help in this situation other than to be a guide as to where the paper sensors are located. There are usually 3 or 4 paper sensors located in Canon PC copiers. The first sensor will be located between the paper pick up assy and the vertical rollers*(*which are located behind the door on the right hand side used for clearing jams). The second sensor is located under the toner cartridge just before the registration rollers. The third sensor (if present)is located at the entrance of the fuser assy (some models of Canon copiers have omitted this sensor)The last sensor is located at the exit of the fuser assy. I would suggest that you remove the cassette, verify that a piece of paper has not been partially fed or ripped in the pick up assy. With cassette out of machine, open right hand door & verify that there is no jam and check that the flag or arm of the sensor moves freely. Remove the cartridge from machine and again verify there is no jam and the registration sensor arm moves freely. If there is a sensor in front of the fuser assy, verify that it also moves freely. Finally, check for a jam and sensor movement at the exit/fuser. After checking all sensors, unplug the machine and plug back in. (Do this without the cassette & cartridge installed but with all the covers closed) This should give you an install cartridge & cassette message. Install cartridge first. This should give you the install cassette message. Install cassette. If you still get a jam signal when plugging the machine in without the cartridge or cassette, the most likely cause is a blown sensor.(rare, but I have seen it.)If this happens you would then need the service manual to disassemble & repair. I'll keep an eye out for your reply! Good Luck!!!
Jun 06, 2007 | Canon PC-795 Copier
Canon imageCLASS D880 All-In-One Laser Printer Logo
74 people viewed this question
old marine
old marine
Corne Viljoen
