Question about Power Acoustik PS2-1250 Car Audio Amplifier
No power to amp
I have professional installed power. Ground wire is perfect, power wire perfect, and the remote wire also sufficent. But the amp light is blank, no red for protection or green for good either. I have a fan placed on top of the amp to keep from overheating. It worked good for 3 days and now i cant get it to work. The day it shutdown I could smell electricity from the amp area. The fan works good and my speakers are brand new. Whats wrong with my amp?
  • 315 Answers
Do you have an inline fuse on the live wire?
Is there also a fuse that you can get to on the amplifier?
Try changing the fuse's to see if thats the problem,
Posted on May 12, 2009
  • 84 Answers
You probably blew it up.
Posted on Jun 19, 2007
SOURCE:
I have installed my gm3400t amp but it will not turn on. Have verified power and ground. Light will not come on. Can you help?
Did you check the remote wire? Make sure it is hooked to the radio is wired directly to the amp. You need to verify that there is 0.5 amps coming through the remote wire. If this is ok, then there is a problem with your amps power supply. (that is if you did verify by multimeter that your power and ground are good). Hope this helps.
Sep 04, 2011 | Pioneer Car Audio & Video
How to hook up the wiring on the crunch 520.5 need to know the gage for power
  • I would go with some good 8 gauge. More than that for this amp would be overkill and a waste. Many people thing thicker wire is better but that is not the case. To thick of wire to the power feed can draw to much power and send the amp into protect mode. Also to thick of wire with an insufficient amount of power can actual hamper the amps true abilities.
  • Use stranded copper wire not solid copper wire for the best results of conductivity.
  • Make sure to run a 50 amp fuse inline with the power wire right off the battery. Amps surge and it is far easier to replace a $1 fuse than components inside your amp.
  • Your ground is best served running to a bolt in the floorboard. Using the same size, style and quality as your power wire is recommended.
  • Your remote wire will connect to the remote wire running from the back of your deck. The remote wire enables your amp to shut off when your deck is shut off. A simple 16 gauge stranded copper wire will suffice for the remote wire.
  • I recommend hooking the speakers up using one speaker per channel. I don't bridge amps really. If you want more power then buy a bigger amp.
  • The AV cords will go from your deck to your amp right to right and left to left.
  • That's the way to wire your amp.
Regards, Tony
Apr 22, 2011 | Crunch P520.5 Car Audio Amplifier
Kenwood eXcelon radio problem I have 2 subs in my civic that work perfectly fine but i recently tried to add another amp to run my front door speakers seperately. I spliced the remote wire between the two...
Cut the remote wire from the radio.
install a relay in line
the relay will have 4 or 5 terminals
connect terminal 87 to battery power and fuse it at 3amps
connect terminal 86 to the remote output from the head unit
connect terminal 85 to ground
connect terminal 30 to your amp turn on wires
this allows the turn on load to run thru the relay and not directly off the radio remote output
Nov 25, 2017 | Kenwood Kdc-x494 Car CD/ MP3 Player
I have this hooked up and works fine with the key on, but when i start the car, sub light, amp and sub dont come on.
You have connected it to the wrong power wire - one that is only active in service mode - first key position.
You should draw a wire directly from the battery (don't forget to add a 40 amps fuse on the wire) to the amps. If you don't want them constantly operational (you will have to manually shut them down) install a relay on the wire with the command coming from a wire from the instrument key position - second position of the key. Use a voltmeter to identify the wires.
Oct 15, 2010 | Rockford Fosgate Power 351M Car Audio...
Sony xplod amp won't work it stopped for no reason
try hooking the amp up with 3 wires, the red power wire, the black ground wire, and the remote wire, do not hook up the speakers at this time
Apr 25, 2010 | Car Audio & Video
How to install
bolt to floor board about 1/2 in. off ground run power, ground, rca, and remote wires to mounting destination conect power to pos remote to remote and ground to ground rcas to rca jacks in both cd player and amp then run 12 guage speaker wire from amp to speakers
Oct 15, 2009 | Kicker ZX400.1 Car Audio Amplifier
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
Amp flashes red light only, no other power seems to work on amp
Hello markrich78,
First determine if it is the amp or the wiring that is causing the problem.
Disconnect all wiring except ground, power and remote turn-on and see if the amp powers up properly. If it doesn't, the amp itself is defective and needs professional repair or replacement. If the amp powers up OK with just ground, power and remote turn-on connected, check all of your other wiring for shorts and grounds, or reconnect them one at a time.
Hope this helps.
Sep 19, 2009 | Kenwood Car Audio & Video
Alpine amp wont turn on..
your power wire is sufficating yor amp probably
Jul 29, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Amp in protect
DUDE CHECK UR WIRE .... AND INSIDE UR AMP THERE MIGHT B A SHORT CIRCUIT OR UR AMP GROUND PLUG INSIDE MUST BURNT OUT
Jun 20, 2009 | Visonik V408XT 250W x 2 Car Amp Car Audio...
Power Acoustik PS2-1250 Car Audio Amplifier Logo
145 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
