I just bought a 1996 Jeep Grand Cherokee Laredo, and when i open the doors the automatic interior lights dont turn on so it is just dark? please help
1. If you have the light switch in the wrong mode the lights will not operate when you open the door.
2. If the interior lights do not operate at all (ie you cannot switch them on and off manually)then you need to check the fuse for the interior lights.
3. When set to the correct mode, the interior lights will operate from a door operated switch so if the switch has failed the lights will either stay on or not operate at all when you open and close the door. Eventually these door switches fail with repeated use and need to be replaced. (Consider how many times the small door switch has been operated since 1996).
SOURCE: The interior lights for my 1996 jeep grand Cherokee Laredo
Hello and welcome to FixYa
The interior lights wont turn off cant because it can't get a conncetion definitely a headlight switch issue common problem for that make
Part # 05137535AA Headlight Switch Probably a dealer item very simple to change this yourself. Hope this gets you going.Please Rate Me. And you can always Ask Me.
SOURCE: 2009 Jeep Grand Cherokee Laredo interior lights won't turn on
check your light dimmer & see if you have it set all the way down.If it's anything like my 99WJ it has an off setting when the dimmer is set all the down causing the interior lights to not come on when you open the doors,hope this helps
SOURCE: 2000 Jeep Grand Cherokee Laredo Door Locks Dont' Work Correctly
you need to check wiring between lf door and body..peel back rubber boot and pull on wires..you will find 1 or more broken wires..can be repaired
