Question about JBL BP600.1 Car Audio Amplifier
No Output from amp, green LED on
The amp is receiving power, i tested it with my VOM. My RCA's are brand new, and i tested them. They are plugged in the right places. My Green LED is on. The Amp used to work then just stopped giving me any output. I tested my subs, and they are good too. Can i repair this?
  • gulabjammun Dec 04, 2008
    all the same symptoms . led is on red light around jbl is on. all wires connected. sub not blown. Did you ever find a solution?
  • kyle14808 Apr 21, 2009
    I have the same problem my amp gets power because green light is on and my subs are brand new, but It's the outputs, how can you replace them?
    New Friend:
  • 83 Answers
Are you absolutely certain your subs are in good shape? have you put a meter on them and measured the ohms as you depress the cone [causing the cone to move up and down on the pole of the magnet? do the ohms stay constant? go up to infinity[ suggesting an open] or go to zero or close to zero [ suggestting a short] both of these conditions will result in a zero or a very limited output from your amplifier, while still showing a green status light, if or when a full short or open occurs on the subs, a fault led will become lit, and whet that means is that u have fried the a bit more testing with your vom....and good luck or try another speaker for testing purposes...
Posted on Jun 30, 2007
Rca 19 inch led hd tv no image no sound
Were all the PS voltages normal?
Oct 18, 2017 | RCA Televison & Video
LED lights up but! ???
Sounds like there is a problem with the amp. Try switching the inputs around for that output on the amp. If that does not help, Yes I would have to say that there is a problem with the amp output circuit.
Nov 06, 2007 | Infinity BASSLINK Car Subwoofer
Looking for manual for pioneer sw200 powered subwoofer
Most subwoofer have a left and right phono/RCA sockets. The amp should have a sub out phono/RCA plug. The sub should have come with a phono/RCA lead that will connect these - one plug to two plugs.
Apart from the mains plug that's all there is really. You may have to switch the sub socket on the amp on.
Or you can get one of the cables from places like below:
Sep 13, 2014 | Pioneer Audio Players & Recorders
LC-42DH77E Sharp No picture Green led comes on then red LED comes on after a short while RED LED flashes twice then reoccurs .
maybe its on power supply try to check at power supply section check nearby parts of regulator ic if you can, test those passive and active parts using vom if those parts are ok then the regulator ic is defective
Apr 30, 2011 | Sharp LC40E77U LCD TV
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Got this amp from a friend and want to wire it up to my Sony head unit. The HU does have pre-out in RCA plugs. please help. I have tried it with: RED - stereo Amp Rem In YELLOW - 12V BLACK - -12V...
Red- 12 volts switched (ignition)
Yellow- 12 volts constant
Black- Ground
Blue/white stripe- remote amp turn on/ power antenna
If you have any orange wires there for the Illumination dimmer. (head unit dims when you turn the lights on). The white and gray are front speakers and purple and green are for the rear, solid being + and black striped being -. (gray and purple are right channels)Make sure that the RCA plugs go to the input side of the amp. I hope this helps, Ray
Oct 11, 2010 | Metra 705512 Ford Prm Snd Amp Plug Wiring...
Hum sound when plug in. if i touch the input jack the hum sound disapear.
The best way to test your sound problem is to buy another pair of patch cables/RCA cables and try those, most likely you have a ground loop in the RCA cables, basically you are creating a ground when you touch it.
Dec 04, 2009 | Fishman Audio Amp Temp - Green Amplifier...
I have a kdc-mp435u and when i connect the subs woofers to it,it dissent put out enough out put Signal to it and when im driving some times it give signal the woofers cussing them to hit heartier. I check...
did you plug your rca signal wires into the subwoofer ouput rca's? if so you can control the level and frequency of the sub on the face in the audio menu. if this is not the issue try new rca cables. you can run them outside the car first just to test. another issue is make sure you have proper grounding on the head unit and amp. also if your rca cables acccidently touch power they can blow a fuse or trace inside the radio causing the rca's to lose ground (you will have low audio with lots of humming noise). you can check this by jumpering a small wire from the radio frame to the outer shield of the rca jack while it is all plugged in. if the sound gets louder and cleaner you can secure this wire in place by soldering it or fixing the circuit board itself.
Dec 09, 2008 | Kenwood KDC-MP435U CD Player
I have a Bosch oven model HBN58066OB. It was used in an exhibition and de-commisioned. The element wires were disconnected for safety reasons and then re-connected. I think the wires are connected...
Step 1: If the oven element doesn't work, first check to see if the range is receiving power. Don't overlook the fusing system inside the range.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale.
Step 4: Remove the screws or plugs that connect the element to the power. Remove the retaining shield, which is usually held by two screws, and remove the element from the brackets that hold it in the oven. The element is usually held in these brackets by screws.
Step 5: Clip the probes of the VOM to each element terminal. If the element is in working order, the meter will read from 15 to 30 ohms. If the meter reads higher than 30 ohms, the element is faulty and should be replaced. If the element tests all right but doesn't work, the problem may be at the terminals. Make sure the terminals are clean and tight at the element connections.
Oven and broiler elements cannot be tested without a VOM. If you don't have a VOM, take the element to a professional service person for testing. The problem is usually a malfunctioning element; however, you aren't risking much by replacing the element without a professional test.
Oct 13, 2008 | Kitchen Ranges
JBL BP600.1 Car Audio Amplifier Logo
406 people viewed this question
Top JBL Car Audio & Video Experts
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
