Question about Kenmore 24032\24036 Top Load Washer
Lint in washer somewhere
I have a kenmore washer 70 series.every time a wash the clothes come out with lint over all our clothes.tried to remove agitator,but doesnt buge.
  • Anonymous Jan 25, 2009
    lot of lint left
    Novelist:
  • 101 Answers
It probably isn't the agitator. Are you sure that it is lint and not the clothes getting torn up? One thing you might want to try is this. First take and pull the basket to one side and clean the gasket on top of the basket. There may be gunk built up on it that is transferring to your clothes. After you do that, just like a coffee maker, put about a cup of white vinegar into the washer and run a wash on hot water. After the load wash again without the vinegar just to make sure it all gets out. This is a good way to keep the washer clean all the time too, do this maybe every 3 months or so. I will clean any hard water deposits built up on the hoses and such and you will notice you clothes coming out cleaner. You can do this with your dishwasher too. Let me know if you have any other questions and if this was helpful to you at all. Good luck and I am glad that I could help you out.
Posted on Jan 22, 2009
I wash all my darks together. No fuzzy stuff either with the black items. Don't overload as I am only person doing laundry. Why the lint left on the clothes. Kenmore Elite Series 600. Please help.
Your Kenmore washer does not have a lint filter. Washers manufactured today and in the past few years are not designed with lint filters. The engineers rely on the dryer to remove any lint left on the clothes that doesn't get flushed down the drain.
overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely.
Lint can be trapped in the load if overloaded. Wash smaller loads.
Use the correct water level? The water level should be correct for the load size. Clothes should move freely in the water.
Alsp liquid detergent works better in cold water and has modifiers to keep lint in the water not on the cloths.
Do you line dry your clothing? If so, you can expect some lint on the clothing.
Check the following too
Was paper or tissue left in the pockets?
Use the proper cycle time for the load? Reducing wash time (duration) is another way to reduce lint.
these should help in reducing the amount of lint left on your clothes.
Thank the wonderful engineers for this problem.
There is one other thing you can do. Micro fiber cloths attract lint like nothing else. Inexpensive ones added to a wash load will catch almost all the lint.
found this out the hard way by trying to clean some that I used in auto body seminars for removing polish and waxes when doing detailing demos. they came out full of lint when washed in a mixed load,..looked worse than they did dirty. well sort of..they were still good for what i wanted them to do but looked like heck. :) if rewashed alone they cleaned up.
hope I helped a little.
Dec 31, 2017 | Kenmore Washing Machines
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Kenmore 400 washer, leaves tons of lint on clothes, no lint basket to clean, cleaning the inside of the washer doesn't help. Black clothes have to be brushed completely with a lint brush to be wearable....
most common cause is that a tiisue or something of that nature went into your wash it breaks uprt and is scattered inside the machines outer bowls,either remove inner bowl to clean it or put it several empty washes to try and get rid of it
Oct 24, 2017 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Clothes come out covered in lint after washing
Sears top load / direct drive washers don't have specific Lint Filters.
See the Use and Care manual for these washers for hints.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0705087.pdf
Apr 12, 2010 | Kenmore 24902 Top Load Washer
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
151 people viewed this question
Sal De
fordexpert
Robert Rankin
