Question about Toshiba 50H81 50" Rear Projection Television
Conversion ready? i have a toshiba 50h81 and hooked the conversion box and a new flat antenna but i get a blue screen that says weak signal what do i do?
    Champion:
  • 240 Answers
Try poshioning you antana.
point small end tord a knowen trasmiter location.
if un knowen call your local brod cast station.
if your high up in the mountians.
forget it at this time thay dont have retrans systems yet.
like poeple in the uper colorado mountans thay have to yous sat for now.
regards.
daniel.
Posted on Jan 16, 2009
The TV is a Toshiba flat screen the remote is a Toshiba CT-9854I need the code so my TV will work with an antenna
Antenna reception is no longer available since the nationwide conversion to digital signal transmission.
Apr 01, 2015 | Toshiba Televison & Video
Weak or no signal
Either the connector on the set is bad or something is burned out. Try connecting to a tv or ext antenna and see what happens.
Apr 01, 2014 | Samsung Televison & Video
Screen has gone to blue screen.....
OK A Blue screen, indicate that there is, or the TV "Thinks" there is NO SIGNAL. Please Check your Antenna Connection. Unplug the TV, for 5 mins or so. You MUST prove either the TV or it's "Signal Source" the Antenna. Try the antenna on another TV, if possible, try another antenna,on the TV, Try feeding in a signal via the EXTERNAL inputs. IF ALL Inputs are proved OK, and the TV, still will NOT display any signal, then it would appear that you may have a "Tuner" fault, or some other underlying condition, that affects the reception. In my professional opinion, in that case is to get the unit looked at by a Toshiba, recommended service center, VERY IMPORTANT to do that. Ask for a "Quote" from that service center, and go from there.
Apr 16, 2010 | Toshiba 37AV500U 37 in. LCD TV
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
May 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Weak or no signal
you would need to know if the tuner is picking up analog signals in the air well( stick a wire a little bit in the tuner connection to see if channels pick up good or use an antenna , if so there should not be a problem with the cable being hooked up to it , if there is a problem even with an antenna then the tuner is bad and will need to be replaced , and the cable could have caused it to go out , but make sure that the tuner is working or not first.
Nov 27, 2008 | Televison & Video
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
No signal on dtv do I need a DTV antenna
You have an awesome antenna - every one should have one like it!
An antenna that used to work with the older analog signals will work with the digital ones. What you have to remember is that analog systems though subject to ghosting, were brutes signal wise ala the metal on older cars. Digital signals are frail and even tree leaves in between the antenna and transmitter can have adverse effect on signal received.
If the sound is weak on your set that is a function of your sets audio section. Somewhere you are losing gain and/or amplification. If you have an audio output you might consider hooking that up to one of the audio inputs on audio receiver. It will work fine and that is what I did with my unit.
Sep 05, 2017 | RCA HD52W59 HDTV Projection Television
Toshiba 50H81 50" Rear Projection Television Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
