Question about D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter
Problem to connect to my wireless after formatting
I was using wireless connection to connect to the net.This was setup and given to me by the company itself. I recently had to format my pc and whn i tried to connect again to the same wireless connection which is secured it does not work. Here are few details
OS: Win xp sp1
wireless: D-link Airplus G dwl g510 (speed stream)
I think that a secure password for wifi router was set up from the same home pc.is it possible the password changed while formating the comp and gone back to the default.i have a laptop which is still connecting to the net with my usual password.
i have tried a lot fiddling with the airg software as well as the normal windows wifi connection process but have availed no results.
Oh , and by the way my neighbours unsecured network(no pasword set) which is linksys works perfectly when i connect there.using that i can connect to the net but my speedstream d-link which has a password set cannot connect.
In my laptop the settings are for d-link........
obtain ip auto
obtain dns auto
network:- wpa-psk
data encry- tkip
I hope you ill be able to solve this problem.
Thanking all of u in advance.
Shawn Fernandes
  • shawn_fernan Jan 16, 2009
    thank u for ur promt response.
    I am currently not at home so i ill reply to the same later this day,
    Kindly let me know how to reset the router.
    but how can the router be the problem since both my laptops are able to connect to it easily.
    the laptops were configuerd before me home pc was formatted.
    Thanks
    Shawn Fernandes
  • Michael Lucas
    Michael Lucas May 11, 2010
    What type of router are you trying to connect to.
    If the router is a problem then you can reset it to factory and wipe out the password.
    Need more info on the router itself. make model.
    If it's a speedstream then what model.
Asd
Posted on Nov 13, 2009
Check ur ip address using ip config.../release the ip address once..and type ip config /renew in cmd prompt...after reseting ur router..check whether ur led in the router,DSL or uplink is buring continously..if not it blinks slowly or a sec of interval..it may ve some problem with the ISP..if i come 2 know ur IPS provider it ll b more helpful for me 2 help u...
Posted on Sep 03, 2009
Unable to browse to cisco access point
'192.168.0.116' is the wrong range for the router. The Cisco manager allocates the ranges the router will use.
See this page on the setup.
Getting Started Guide Cisco 3700 Series Access Points
May 28, 2014 | Cisco Computers & Internet
Failure to connect to internet
hello there,i would like to try and help you. could you please provide me with the details you see under network information:
IP Address:
Subnet:
Gateway:
DNS1:
DNS2:
is your internet service subscription valid? what type of wireless router are you using?
Mar 18, 2013 | Acer Aspire One PC Notebook
Hi. i'm trying to get my girlfriends notebook(advent 4213) connected to the net. i am using my own wireless net but when i click on the net it comes up saying this page cannot be displayed. do i h
If the Advent notebook normally connects to the internet without problem on her network, then you need to check the following:
1. That she does not have any proxy connection setting in her web browser that you do not use on your own network.
2. Check that her wireless adapter is configured to Obtain an IP address automatically and also Obtain DNS server address automatically.
3. Check the status of the wireless adapter connection and ensure that the Advent notebook has been given a valid IP address, i.e. if your are connecting to a wireless router on your network, you should see an address something like 192.168.x.x where the x.x depend on how your router is setup. If you see a 168.x.x.x address then the notebook is not getting a valid, routable IP address and you should try to do a Repair of the network adapter connection. Repair may also be shown as Diagnose and repair depending on which version of Windows is used.
Jan 07, 2012 | Computers & Internet
Netgear Wireless router logon problems
You probably typed in the router password instead of the Wireless password. Connect your PC to the router via a network cable type in your web bvrowser 192.168.1.1 , login to the router and in the Wireless security section change the passphrase to something and write it down then try re-connecting via wireless after unconnecting the net cable
Aug 09, 2009 | NetGear WNR2000 Wireless Router
My router cannot detect my internt
hello! there is a possibility that the internet connection setup of your router is not proper setup.. ex.. you need to know what kind of modem u use for ur internet connection, if you are using a cable modem, u need to mac clone the network interface card of your computer. if you are using a pppoe connection, u need to setup ur router using the username and password given to u by your isp, or maybe your setup is on a static ip addressing.. to check ur ip address that is giving by your modem.. connect ur computer directly to the modem and click on star, then run and type in to the box cmd and it will give u a dos mode prompt.. type in ipconfig/all and it will list the ip address, subnetmask, default dateway and the dns server..you can check first with ur isp what kind of connection u use for interner access
Aug 06, 2009 | Linksys WRH54G Wireless Router
Connecting with internet
Yes, that is possible since you have a wireless router. Router can share internet connection. Go to this link this will help you setup the wireless connection (secure it if you want)
http://www.portforward.com/english/routers/wireless/Dlink/DI-524/wireless.htm then on the very bottom there is an option how to Configure Windows XP to connect to your wireless network.
I suggest this because it would be better if there is encryption on the network so people wont be able to access your internet for free (unless you give them the security key)
Sep 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless connection problem. laptop ip address is 60.60.x.x
D-LINK WILL HELP YOU...
Set up your new D-Link networking hardware in minutes using our new Quick Setup Wizard. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
Jul 05, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Linksys router not performing
has it worked before? if yes, try to power cycle everything. turn off everyhting then turn on the modem first, then the router, then the computer/s.
if you have power cycled everything already and you still can't access the internet using the router,
- access the router's setup page by logging to http://192.168.1.1 (leave the username blank and the default password is "admin")
- if you're using a cable connection, set the connection type to "automatic configuration - dhcp" and enable the mac address clone
- if you're using a dsl connection and you have a username and password from your isp, set the connection type to "pppoe" then enter the complete username (ex. username@comcast.net) and password given by your isp.
- check the "status" tab of the router and see if there's an internet ip and dns, if so, you should be able to connect to the internet
hope this'll help you.
ciao!
Jun 20, 2008 | Linksys Wireless-G Broadband Router
How to Configure Nomadix AG2000W from scratch
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 21, 2008 | Nomadix AG-2000W 802.11a, 802.11g/b...
D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter Logo
823 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
