Question about Microsoft Office Professional 2007 Full Version for PC
My computer has been upgraded to Office 2007. I want to type a single file label. I went to Mailings instead of tools as before and selected labels. However, I cannot find an Option for Avery template 5266. Formerly, I was able to select the Option and then press New Document to see a blank page of the labels. What are the steps in Office 2007 please?
  • 3 Answers
You're close. After selecting labels, select the options tab at the bottom. Then, under Label vendors, choose Avery US Letter. Then scroll in the window to find 5266.
Posted on May 30, 2009
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 205 Answers
If you do not fine avery labels you have option of customizing the labels in Publisher to the dimension of avery 5266 .
Posted on Apr 10, 2009
Can you print address on envleope
Yes you can print an address on an envelope. Do you have Microsoft Office? If so, click on new office document and click the tab that says Letters & faxes (for versions before 2007) and choose the label wizard. When the window opens, click the tab that says envelope instead of label and follow the prompts to type in the information you want to print on yoru envelope.
If you have Office 2007 - or newer, click on new office document and then choose blank document. Click on the tab at the top that says mailings and then choose envelope and type in the information you want to print on your envelope. Then click on file, and print. You will need to load your envelopes in the printers tray and put them in the correct direction according to the settings your machine requires. You might need to waste a few envleopes until you get it right.
Oct 22, 2011 | HP Photosmart C5280 InkJet Printer
How does one print envelopes on the xerox pro 232?
descicon.gif function showThisURL(){ $('.urldisplay').show(); } function hideThisURL(){ $('.urldisplay').hide(); } email-icon.gif print-icon.gif btn_remove_x.gif Return to Search Results Solutions for : How To Print on Envelopes in the Bypass Tray or Optional Envelope Tray Solution : Print on Envelopes in the Bypass Tray or Optional Envelope Tray This solution assumes that Number 10 envelopes are being used and printed on using Microsoft Word 2003 or 2007. Steps may vary if other applications are used.
NOTE: If necessary, make sure the envelopes are loaded correctly in the Bypass or Optional Envelope Tray. See the Related Items below for additional information.
From the computer using Word 2003:
  1. Open the application, and then select [Print] from the File menu. The Print window will be displayed.
  2. Select the required printer, and then click on [Close].
  3. Select [Envelopes and Labels] from the Tools menu. The Envelopes and Labels window will be displayed.
    NOTE: For Office 2003, click on [Tools], then [Letters and Mailings], and then select [Envelopes and Labels].
  4. Click on the [Envelope] tab.
  5. Enter the address and other information in the fields provided, and then click on [Options].
  6. Select [Size 10 (4 X 9.5)] from the Envelope size pull-down menu.
  7. Click on the [Printing Options] tab.
  8. Click on the second icon from the right under the For Feed Method section.
  9. Click on [Face-up].
  10. Select [Default Tray (automatically select)] from the Feed from pull-down menu.
    NOTE: If the Envelope Tray is being used, select [Tray 2].
  11. Click [OK].
  12. Click on [Print] to begin printing.
From the computer using Word 2007:
  3. Click on [Mailings] tab.
  4. Click on the [Envelopes] icon.
  5. Click on the [Envelopes] tab.
  6. Enter the address in the Delivery Address field.
  7. If necessary, enter the return address in the Return Address field.
  8. Click on the [Options] button.
  9. Click the [Envelope Options] tab.
  10. Select [Size 10] from the Envelope Size pull-down menu.
  11. Click the [Printing Options] tab.
  12. Click on the fifth icon from the left from the Feed Method section.
  13. Click on the [Face Up] radio button.
  14. Select [Bypass (Tray 5)] from the Feed From pull-down menu.
  15. Click [OK] twice.
Nov 23, 2010 | Xerox Office Equipment & Supplies
How do I get my hp deskjet 6940 to print labels. I'm trying to print Avery 5498 labels
You will have to use software to make the labels...like Microsoft Office Word, Open office Writer, or Microsoft Works. In MS Office Word (2003) go to tools->letters and mailings -> envelope and lables. Create the label you need.
If you use open office, go to File->New->Labels and create the label you need.
After which, you put the paper in the printer and print them out. May want to check out the size so you make sure it prints correctly.
-best of luck
Oct 21, 2010 | HP Deskjet 6940 InkJet Printer
Labels not lining up corectly
Go to printer options and select "Fit To Page"
May 24, 2017 | Microsoft Office Standard 2007 for PC
Labels are not set up with correct dimensions
Go to Mailings > labels > Options > Select Printer Info > Label Vendor > Product Number
Nov 18, 2009 | Microsoft Office Professional 2007 Full...
How do i transfer a list of name to #02180/02181 avery
Microsoft word has the avery stuff in it. This is from another site
Try this:
In Word versions prior to Word 2007 (Vista):
1. Click the Tools->Letters and Mailings->Envelopes and Labels menu item.
2. Click the Labels tab.
3. Click the Options button.
4. Find that label in the list box. Avery tends to use four-digit product numbers, so I'd take a look at the 2181 type and see if it fits the size and description of your labels.
5. If you find it, select it and click OK.
From there, you can make a full page of the labels by clicking New Document, or, if you want to print the same label a few times, you can print a short batch directly with the dialog box.
In Word 2007:
1. Click the Mailings tab on the Ribbon.
2. Click the Label icon.
3. Continue with Step 3, above.
Hope that helps.
Sep 15, 2009 | Microsoft Windows XP Home Edition
Printing Avery Labels
click on "mailings" then labels. Then set up your lables
May 27, 2009 | Microsoft Office Word 2007 Full Version...
I am having problems with a mail merge for tent card 5302 - can someone tell me how to merge an exisiting excel document into word?
In Word 2003:
Open the Tools Menu >> Letters and Mailings >> Mail Merge.
Select Labels and click Next
Click on Label Options and select your tent card and click OK and then Next
Select Use Existing List and click Browse to find your Excel document. Click Next.
Add in the fields you want on your cards to the first and then click Update All Labels.
Finish Mail Merge Wizard.
-- Word 2003 doesn't come with the 5302 label template. You'll need to download that from http://support.microsoft.com
In Word 2007
Select Mailings from the menu list at the top,
Click on Start Mail Merge and select Labels
Select Label vendor Avery US Letter
Select your product number 5302 and click OK
Click on Select Recipients from the top and select Use Existing List to browse to your Excel document
Using the buttons on the top for Address Block/Greeting/etc add in the fields you want to the first label.
Click on Update Labels
Click on Finish and Merge
Apr 28, 2009 | Computers & Internet
I have an Intermec PF8t printer with InterDriver Windows Driver -- How can I get my labels created in Microsoft Office to print? How do I specify label size?
depending on what version of office your using you will find a label tab under mailings (in office 07) or under tools (previous versions) you should be able to specifiy a label type or build a custom label.
Dec 10, 2008 | Intermec Office Equipment & Supplies
I can't print on the 5354 labels from microsoft word
TOOLS
LETTER AND MAILINGS
ENVELOPES AND LABELS
Labels Tab, Options.
Now not sure what make your label is, so you will need to locate it from the list. If that isn't possible.
Goto Details - and enter the dimensions of your label and save for future use.
Sep 18, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
284 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
