Question about HP LaserJet 4100n Printer
Error code 10-2 on a laserjet4100
Wont print says tray 2 is open when its not
  • 71 Answers
Try another paper tray.
Posted on Jan 16, 2009
Pixma ip660d displays 6500 error code
Hello
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Feb 17, 2011 | Canon Pixma iP6600D InkJet Photo Printer
I got a error code C-0204 and I`ve checked the tray 2 and is everything ok, but i still receiving this message and i cannot print. Please any help?
C0204 as I see you already know is a tray 2 elevator failure. Meaning the machine does not see tray 2 lifting up the paper. This is usually caused by improper paper loading, elevator sensor failure or lift motor failure. You can still use the copier/printer if you leave tray 2 open and inch or 2. Just use the other trays until repairs can be made.
Good Luck and Thank You for using Fixya.
Sep 25, 2010 | Konica Minolta bizhub C250 All-In-One...
Display shows error code 6500. how do I fix the error
4. Properly seated
Aug 15, 2010 | Canon MP830 All-In-One Printer
Error code
4. Properly seated
Good Luck!!
Thanks
Oct 01, 2009 | Canon Office Equipment & Supplies
Ip 5300 error b200 10 blink orange-green
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Sep 26, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
Cannon mp830 error code 6500
4. Properly seated
Good Luck!!
Sep 20, 2009 | Office Equipment & Supplies
Screen shows error code 6500
4. Properly seated
Good Luck!!
Thanks
Sep 09, 2009 | Canon Pixma iP6600D InkJet Photo Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
HP LaserJet 4100n Printer Logo
43 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
