Question about Panasonic KX-TGA101S Cordless Handset
People cannot hear me
On one of the phones in this set of three, people cannot here me when I call.
  • brulincoln9 Jan 20, 2009
    I had previously check this. It was not the problem. I called the companies help desk. They had me take out the batteries for awhile and that reset it for awhile but it keeps happening
    Problem Solver:
  • 9 Answers
I would think either your mute or your headset feature is activated. Mute button is obvious and the display should say mute. The headset also should have an icon on the display however you may have to turn it off in the MENU screen. .
j
Posted on Jan 16, 2009
Set up gmail account
Go to the Google website and change your global password.
Sep 09, 2014 | Cell Phones
People can't hear me durring calls. I can hear them.
Three possibilities: you have muted your microphone (sometimes by using an external mic it turns the internal one off), you have turned the mic down to the point where it's so low it isn't picking anything up, or the mic is broken.
Look around under settings and check the mic volume and mute settings. If they are okay then I'd say the mic has gone south.
Mar 06, 2014 | Samsung SCH-U380 Brightside Verizon Phone...
Our phone rings only twice and then goes to the answering machine. How do I change the number of rings to 4 or 5. I lost the Uniden user manual.
With the phone in standby mode, press the menu/clock key three times.
You hear "Ring time" and the current ring time, and it is displayed on the main base. Then you hear the guidance for setting the ring time.
Press the volume/select-up-down until the desired setting appears.
Press the set key.
Full instructions are in the "Setting the Ring Time" section of the manual (page 36 in my copy). If you need a manual, you can download a copy at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DXAI5588-2om.pdf
Sep 16, 2011 | Uniden DXA15588-2 Twin Cordless Phone
I cannot hear people when they call me but they can hear me. If I call out I can hear the other person but they cannot hear me
There are three possible problems that I can think of.
1) Probably the most obvious. Your microphone is broken. This could have happened if your phone took a tumble
2) The wire inside of the phone connected to the microphone is disconnected or ripped.
3) You have your in-call settings on Mute. Next time you make a phone call, see if it says "mute" anywhere on the screen.
I would bring the phone to your carrier's nearest store and have them look at it. If it's a problem that arrived without you being at fault, they should replace it for free.
Hope this helped!
Please rate my solution
- Frankie
May 06, 2011 | Motorola Mobility Defy Cell Phone
My Nokia 6233 has suddnely displayed the headset symbol when I have no enhancements connected. Obviously when someone calls I cannot hear them talk. What can I do to fix this ... I have turned the phone...
Just follow the steps
Make a backup of contacts in your another sim.
Try to Restore factory settings
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3"
"green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory
stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Nokia 6233 Cellular Phone
How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
http://www.uniden.com/pdf/DXAI5588-2om.pdf
Bill B
Mar 04, 2010 | Uniden DXA15588-2 Twin Cordless Phone
When I get calls, I cant hear anything out of my phone unless it is on speakerphone, but the person on the other end can hear me perfectly. This has happened in three different Venus' that I have had...
did you change your earpiece setting on the my settings menu, it's under Sound settings. you can change it to low to high. And when you answer the phone, you traditionally answer it the portrait way?
Mar 06, 2009 | Verizon Communications Samsung Alias Cell...
Nokia E90 Communicator - callers can hear me but I cannot hear
try to format your phone, and check if thhe problem persists.
FOR SOFT-RESET:
- at Standby Screen type-in => *#7780#
It will ask for “Restore all phone settings-phone’ll restart….”
Then it asks for security code enter factory default => 12345
FOR HARD-RESET:
- at Standby Screen type-in => *#7370#
FOR FLASHING- TOTAL RESTORE: (Do this if your phone does not boot up)
1) Remove the battery, and then wait for about 20 min or so before putting it back
2) Press and hold these three keys together -Green dial key, Star key[*], Three key [3]
3) switch ON the phone.
4) Do not let go the three keys until you see the WELCOME screen displayed and just let it complete the boot process.
check if this helps. if this doesnt help contact Nokia Care Point-> http://europe.nokia.com/A4388379
thanks for using FixYa
Mar 04, 2009 | Nokia Cell Phones
Cannot call out or answer a call
The only thing I can think of is you may be in the wrong dial mode. If you do not have touch tone service you will hear the tones but it will not connect. Try setting it to pulse and see if you can call out. Check you volume or see if the mute has been set. Have you tried a different phone? you might want to borrow a phone from a neighbor to see if it is a service problem or just your phone.
Feb 01, 2008 | Panasonic KX-TG6021 Cordless Phone
Panasonic KX-TGA101S Cordless Handset Logo
266 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
