Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Socket connect error
How do I fix the socket connect error.
Thanks,
Debbie
  • 210 Answers
CHOOSE HTML AND NOT FLASH.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
I have aLCD HDTV-LC-332D4OU TV
Hi-
Try taking cables from the back of television and turn it off and unplug it for an hour and try turning it back on. is there any lights blinking or flashing in the control panel? try resetting the settings to default as well. Keep us posted. Thanks for using fixya!
Aug 17, 2008 | Sharp Televison & Video
Electrolux icon side by side fridge is flashing E and F instead of holding the temp for the freezer and fridge. How can I fix this?
Hello Debbie Zymet - Typically error code E and F indicates that there is an error with the evaporator fan in the refrigerator compartment and fan in freezer. I would suggest contacting a professional move forward accurately for proper diagnosing and repair.
Nov 18, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Keek -forbidden(error 408) solution
HTTP Error 408 Request timeout
Introduction
The Web server (running the Web site) thinks that there has been too long an interval of time between 1) the establishment of an IP connection (socket) between the client (e.g. your Web browser or our CheckUpDown robot) and the server and 2) the receipt of any data on that socket, so the server has dropped the connection. The socket connection has actually been lost - the Web server has 'timed out' on that particular socket connection. The request from the client must be repeated - in a timely manner.
408 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '408'. (Last updated: March 2012).
Fixing 408 errors - general
408 errors are often difficult to resolve. They typically involve one-off variations in system workload or operations.
If you see persistent 408 errors, the first thing to consider is the workload on the Web server - particularly around the time the 408 errors were generated. If this is light, then you also need to consider workload on the client system. If the computer systems on both ends of the socket connection seem to be running normally, then temporary Internet surges may be to blame.
Fixing 408 errors - CheckUpDown
This error is highly unlikely to occur on your CheckUpDown account, because there is usually only a tiny interval of time (milliseconds) between our 1) opening of the socket and 2) writing the HTTP data stream through that socket. In exceptional circumstances, this interval may increase because of some operations on our computer systems e.g. we temporarily suspend an executing process and this happens immediately after the socket was created. Or the two steps may follow quickly on our systems, but the second step encounters an unreasonable delay on the Internet. The acceptable interval between the two steps could also be set very low on the Web server e.g. the Web server is very busy, and has become a bit 'impatient' with attempted connections it views as a bit slow.
Any of these conditions may generate an 408 error. But they are all fairly unlikely to occur. In normal IP communications, the time interval between the two steps should be much less than 10 seconds, which should be completely acceptable to the Web server.
I hope this helps.
Oct 23, 2012 | Computers & Internet
Dear Mr/Ms, I think my ecosave washing machine has some mis-functions. Whenver what process has been done, symptoms are the same. The symptoms are the followings . . . . - blinking error LED light:...
The error came from an electronic control, the damage usually occurs in the data memory. under normal circumstances should have after finishing washing or spin process, washing machine will turn off automatically, indicated by the beep sound and flashing lights first. if you quite understand you just need to fix the electronic control block only, reset IC memory or the easiest way is to unplug all cables (socket) connected to electronic control, turn on the washing machine and then power off and reattach all the cables socket into place. particularly note the socket cable of  water level sensors and unbalance switches. electronic control block is usually coated with rubber glue. but I often fix it without having to replace the whole (one block / set electronic controls). good luck
Aug 07, 2010 | Washing Machines
Chantersamo - clean 46 solution
Yes fixed, sorry for the confusion. Debbie
Jun 06, 2009 | Brother DCP 130C All-In-One InkJet Printer
There seems to be a fault with the connection on my 3.5mm audio-in port (intermittent signal). Is there an easy fix for this or would it be better for me to look at an alternative for my audio-in (3.5mm to...
Via trial and error really I enabled the "line-in" socket in Sound settings and it works OK. I also enabled the Dolby Virtual Speaker and this now gives me both channels from my 3.5mm audio-in jack socket...thanks. Sharon.
Aug 19, 2008 | Audio Players & Recorders
Hi, i have a problem with my toshiba regza, 32" about 18 months old, keeps changing screen width to 4:3 from widescreen on some of the music channels on sky! keep resetting it but still does it next...
Hi Debbie,
Check the picture format setting on your Sky box.
Press Services.
4 for set up.
1 for Picture.
Theres and option that says 16:9, 4:3 or 4:3LB, make sure its set to 16:9.
Then go to Save settings and press the Select button to save the setting.
Regards
Andy
Jun 26, 2008 | Toshiba Televison & Video
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
259 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
