Question about Microwave Ovens
Panasonic microwave nna811a looking for a timer control module or timer control board mine has been burntout. It had a power surge from a 3ph supply one of the ph touched a neutral in the fuse box on wall
  • Microwave Ovens Master
  • 9,098 Answers
Panasonic's UK site is here, and you can use the support links to find spare parts and servicers.
Posted on Jan 18, 2009
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Panasonic NN-C2003S microwave is completely dead. No lights, no action. Have taken cover off and checked fuse, which looks like it is in good condition.
Would need to check power to main board. A lot of times it is the small low voltage transformer on the main board. If the primary winding goes bad it cant get power to the rest of the board to function. So to start, is there power getting to the low voltage transformer on the main board??Have you had any thunder storms or power surges at your home where it is plugged in? If a home loses its Neutral power line it can mess up a lot of electrical devices in the home. do you notice your lights browning at times. If so you may need to get your power company out to do a load test on you system. But the transformer is a very low amp device and will not blow the main fuse if it goes bad. So you could bhave aburnt trace on the back of the main board or a bad transformer. Best guess. Good luck
Jun 26, 2017 | Panasonic Microwave Ovens
No power dead
power outages cause power surges and will damage electronic control boards. I suggest replacing the Control board and checking the interlocking door switches. Whilst inside the microwave check the magnetron for discoloration around the magnetron horn or gun as it were. If it don't look clean and new, otherwise burnt it's bad !
Feb 06, 2014 | Sharp Microwave Ovens
Panasonic nn-sd277. the only thing that seems to work is the clock and the timer. If you try to get it to work there is snap and it quits. Ours was made in may of 2010 and purchased shortly after that
follow this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Oct 20, 2013 | Panasonic Microwave Ovens
No power to my microwave GE JVM1750DPBB
You're looking $130.49 for the board.
May 01, 2012 | GE Microwave Ovens
No power on microwave panasonic NN-S255
It all depends on your full model number (you left off the suffix) but one version's service manual is here.
In some cases, it is a fuse or thermostat / thermal cutout / TCO, in others a surge has occurred, requiring circuit board repair.
This surge can be from the power line, or due to blown cooktop bulbs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Panasonic parts at
Encompass here.
Dec 04, 2011 | Panasonic Microwave Ovens
No power
Either the fuse inside is blown, or the power supply is shot. You can remove the cover of the oven, and look inside at fuse. You can test power supply / inverter with a voltmeter to see if there is power to the main circuit board.
May 11, 2010 | Panasonic NN-H264 Microwave Oven
We had a pwer surge, all e?ctrocs went ou, all started up with the exception of the Microwave, it 9is Pansonic Combi 18 month old
Chances are the control circuit board on the microwave needs to be repaired. It has built-in surge protection that's usually pretty effective.
I would strongly suggest that you ask if the servicer does "component-level repair" on microwave circuit boards, as opposed to just replacing the whole board. This can save you a good deal of money.
If you cannot find a servicer who does component-level board repair, you can refer the servicer here for instructions.
I'm guessing you're in the UK? If so, you can find a local Panasonic-authorized servicer here.
If you're not in the UK, just visit here, select your region / country on the maps, then click Support and find a link for locating a servicer.
Sep 27, 2008 | Panasonic Microwave Ovens
Panasonic NN-S789WC - No power on Display, Fuse OK, bulb Lights
The fuse will be a white or gray ceramic fuse, and you really can't tell if it's blown without actually measuring it. If a new fuse blows when you hit START, you probably have a shorted high voltage capacitor. If you have replaced the fuse and still have no display, then it sounds like there's a problem on the control board. The control board has a built-in surge protector which can short (and smoke) and when it does, it will cut the power to the control board, but not blow the fuse. We repair these nationwide for only $39.95 postpaid. If you or a friend want to check it out or send the control unit in for serivce, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 02, 2007 | Panasonic NN-S789 Microwave Oven
Power but no display to unit
Not sure about the Neff brand, but in general you'd want to check for 110VAC power on the primary side of the low voltage transformer on the control panel / board. If that is present, check the secondary for voltage, about 12-30VAC. If the unit has a VFD type display, there will be a heater filament supply, usually around 2.5-6VAC. Also look for bad connecitons on the VFD. If those voltages are present, check connections on the board, look for bloated / bulging capacitors, shorted diodes, breaks in the board, etc. Also look for thermal cutouts and thermostats. If this doesn't fix it, can you take several photos of the inner parts and circuit boards?
Sep 26, 2006 | Neff H7871A2GB 800 Watts Convection /...
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
