Question about Pioneer HTP-2900 System
Pioneer htp 2950 home theater system
Cannot increase volume. read out goes from (-94) to (0)
    President:
  • 3,130 Answers
There is a problem with the volume controller chip, or a problem in the paoer supply feeding the main amp. Good Luck
Posted on Jun 19, 2007
How do i fix my remote to work my home theater. i have a htp-071 and my remote stopped working. the battries are brand new. I went away for the weekend and came home, remote didnt work. please help.
Test remote for operation. Problem is with either the remote or the receiver in the home theater.
Clean all battery contacts and install new, tested, working batteries in remote. Turn on am radio and tune AM dial to about 600 - turn up volume. Then bring remote to about one inch from radio and hit button on remote. You should hear a beep as long as you hold the button down. Every button will respond likewise. If nada at all remote is trashed, if works with some buttons then you have a partially operating remote. Try cleaning contacts for buttons that do not work or use some aluminum foil under those non working contacts.
Nov 22, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
Had to move furniture around and trying to re-hook up my Pioneer 2900 receiver to the back of my computer. Am using a y-adapter, as I have in the past - but either plugged into wrong jacks on back of...
So what's the question? How many heaphone or speaker out jacks does your PC have? Any one will work provided you have trhe sound controls enabling it and the volume turned up.
Any available Line Levl input on the Pioneer will accept the output from the PC.
Mar 16, 2011 | Pioneer HTP-2900 System
I have the VSX-1019AH-k Pioneer receiver and i want to increase the bass. When i go to setup for the speakers the SW option is grayed out so i can't put it to plus. Help?
I'm referencing a VSX-1016 manual, so I hope it's close enough to help you find the function...
Somewhere in the System Setup menu you'll find a setting for SUB W. The wrong setting is NO.
Set it to YES or PLUS depending on if you want ONLY the Sub to carry all the bass, or if the Front Speakers will share bass with the Sub, respectively.
Dec 25, 2009 | Pioneer HTP-102 System
Receiver won't let volume go higher than -7 dB
Actually, -7 db and above woul be quite load.
Anyway, I am not very familar with the Pioneer GUI auto setup. But, am aware of how AVR are set-up.
If you have set up the home theatre by auto/manual setup then please check the channel levels whether any of your channels settings is at +7.0db.
If so, reduce this setting where it more +7.0, then you would be able to raise the overall main setting from the volume control to go higher than -7db.( by as much as you've lowered the particular channel setting)
Please do let me know if this helps.
Apr 29, 2009 | Pioneer VSX-1018AH-K Receiver
How to hookup to u dvr dish reciever to pioneer surround sound
You will need to run the video cable to the telivision. You will need to take the digital feed from the dvr and run it into the pioneer digital input.
Jan 28, 2009 | Pioneer Dolby Digital 5.1, Pro Logic II...
PIoneer Htp 2700 stopped working
Unit still under warranty. Best bet is to contact Pioneer for the location of their closest authorized factory repair center and ship unit to them for warranty repair. Or check out ebay for a used unit or parts being sold.
Jul 28, 2017 | Pioneer HTP-2700 System
Pioneer HTP-100-SW
i just installed my htp 100 sw. the scheme was atached to the back of the woofer for me tho. easy. front speakers go into the sub in the two botom inputs from the receiver. the two upper are outputs to the actual speakers. hope it helps
Dec 24, 2007 | Pioneer HTP-102 System
Subwoofer
I suppose that your system requires an active subwoofer, and that you provide one. Some systems, if SPEAKER SIZE in SETUP are set to LARGE for front or center speakers, do not send signal to sub, system redirect signal to front or center speaker. Try to check this.
Oct 05, 2007 | Pioneer HTP-2900 System
Sound Problem
the amplifier must have an individual speaker volume controller that allows you to set different volume levels for each speaker independently, find it and set new levels.
Apr 29, 2007 | Pioneer HTP-2800 System
Pioneer HTP-2900 System Logo
239 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
