The small tube is wrapped with little bristles and it appears to be intact. I believe it penetrated the radiator. Is this the bottom of the radiator or is it the transmissin cooler? Coolant is leaking pretty fast.
Get the
coolant pressure tested, its definitely leaking coolant. You will need to get
the coolant running line. Pressure
test will help you to know from where exactly coolant/refrigerant is getting
leaked. =========== For complete
step by step troubleshooting i suggest you to go through the help link mentioned below :---- COOLANT
LEAK ISSUES, COOLANT LEAK PROBLEMS, COOLANT SENSOR, LOW COOLANT,
Click
the link below: -----
http://alltypesofpartsreplacing.blogspot.com/2012/12/coolant-leak-issues-coolant-leak.html
These will help.
Thanks.
SOUND LIKE DAMAGE RADIATOR.
