Question about Lexmark Optra S 1855 Laser Printer
Can't print from bottom drawer, will only print from tray,
Lexmark optra s 1855 laser, need to know how to program the printer to print from bottom drawer default
    Genius:
  • 1,018 Answers
There are at least three possible solutions. The first two are simple the third is fairly complicated unlr=ess you can read a hex dump of a print file. 1) Use the front panel "Paper Menu" to select the tray. 2) Check the driver settings to make sure the driver is set to "Auto" or the correct tray. 3) Set the driver to "Print to File". When prompted to name the print file, name it "tray_fail". If you do not know how to read this file, send it to me at janddgasrepair@verison.net and I'll be happy to take a look at it and see I I can correct the problem. Don
Posted on Jun 03, 2009
Paper tray on optra n is not coming up and message says load paper
Check the paper guides on the paper tray, check if they are set to the correct paper size.
Dec 13, 2012 | Lexmark Optra S 1855 Laser Printer
Good morning, I bought a acer aspire 7540G laptop with Windows 7, 64 bit. I connected the Lexmark Optra S 1855 printer with the USB but my computer cannot find the driver. Where can I find the correct...
You may click on the following links below to download the available printer driver for this printer model.
http://bit.ly/oLHVX3 - 64-bit PCL XL Emulation Print Driver Universal Print Driver
http://bit.ly/p0RF71 - 64-bit PCL 5 Emulation Print Driver Universal Print Driver
http://bit.ly/oOi99g - 64-bit PostScript Level 3 Emulation Printer Driver Universal Print Driver
For further assistance, please contact Lexmark Technical Support
Jul 26, 2011 | Lexmark Optra S 1855 Laser Printer
I keep getting a paper jam error with my Optra S 1855 printer, but there is no paper jam. This error interchanges with a message asking me to Change the paer in tray 1 to letter size, but it is already...
Open the tray and make sure the green paper lever is set to letter mark, both at the bottom of the paper and the one on the side. And yes, if you haven't used it for 3 years, you should clean the dust that settled inside your printer over time.
Dec 06, 2010 | Lexmark Optra S 1855 Laser Printer
It started getting jammed recently quite often and generally happens when the paper tray isn't full. It usually either gets jammed near the tray or in the back.
i take it that you getting mutiple different jams and pretty often correct? these printer use a paper size select pcb when these start to go bad the paper size can be change every time you close the drawer or every other page you print. print your network page and see if it prints as big as the page if its smaller the printer thinks it has smaller paper if the lower black line of the box around this page is missing it thinks it should have longer paper. this board is located behind the metel box the logic board is mounted in. for cheaper prices,instruction and support for your lexmark lasers go to L-tech4u.com write an email if you dont see what you need listed they will have it
Nov 12, 2009 | Lexmark Optra S 1855 Laser Printer
I HAVE A LEXMARK OPTRA S 1855 DISPLAY NOT READABLE HOW DO I PRINT A TEST PAGE UNHOOKED FROM THE COMPUTER?
Hello, Leo.
Here are the steps:
  1. Turn the printer power off (O).
  2. Press and hold Select and Return together.
  3. Turn on the printer.
  4. Release the buttons once Performing Self Test appears on the operator panel display.
  5. The printer performs its normal POR cycle, then prints one copy of the Print Quality Test pages.
Hope this helps.
Oct 15, 2009 | Lexmark Optra S 1855 Laser Printer
Lexmark optra s1855 makes knocking noise when printing envelopes from the mp tray
this noise is usuallt cause by a flat spot on the backup roller of the fuser remove the fuser turn it by hand if you feel a flt spot when turning replace the fuser
Sep 23, 2009 | Lexmark Optra S 1855 Laser Printer
Swap parts between Optra S 1255 and 1855
I can say for sure that these parts do not translate. The service manual says.
Jun 09, 2009 | Lexmark Optra S 1855 Laser Printer
My Lexmark Optra S 1855 is showing a fuser error. What needs to be done?
the fuser needs to be replaced its about 200 dollars just search for Fuser for the model of your printer
Thank You John C
Mar 03, 2009 | Lexmark Optra S 1855 Laser Printer
Our lexmark Optra T610 laser printer keeps telling me to "change tray one to plain paper"
verify paper tray is set for correct paper. print the configuration menu and check the paper size for tray 1. If it does not have right size, examine the tray bottom to see if slider is in place
Feb 03, 2009 | Lexmark Optra T610 Laser Printer
Lexmark Optra S 1855 Laser Printer Logo
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
