Question about Canon imageRUNNER 210S Copier
Solve System Error E001
When I turn on my Canon ImageRunner 210S, there is an error on the screen that reads
"Switch main power Off and On
E001"
At the same time, the error button by the Copy button is flashing.
I checked to make sure there isn't a paper jam, and I tried pushing cancel, reset, and some other buttons, but nothing happens.
Does anyone know how to fix this error or what it means?
Thank you!
  • 100 Answers
It needs a new fixing unit. Youll need to call a tech for this, the finixing unit cost the dealer 180 bucks and the make up is around 50% so its not a cheap unit. There also adjustments that need to be made in service mode so you really need a Canon tech that knows how to get into the service mode and make those adjustments for the new part.
Posted on Jan 16, 2009
How to remove error code (E000004-0010)from canon
Use this mode to clear an error code: E000, E001, E002, E003, E004,
E032, E717.
Using the Mode
1) Select <ERR> to highlight, and press the OK key.
2) Turn off and then on the main power switch.
Jan 05, 2013 | Canon imageRUNNER 5570 Copier
E00001-002 Error cod?
Thanks for using Fixya.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Go into service mode, go to COPIER > FUNCTION > CLEAR > ERR.
Select ERR to highlight, and press OK key.
Turn off the copier using the main power switch (on the right side of copier).
Wait at least 10 seconds and then turn the copier back on using the main power switch.
If the error is still there then you will need to take your printer to a canon service center.
Good luck and have a nice day.
Nov 08, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
On copier sow display bord "Swith main power off and on E001
When switch on ImageRUNNER 330s Grayscale Copier then no display on dispaly board. But Copier front yellow led is on. Please solve this problem.
May 29, 2009 | Canon ImageRUNNER 330s Copier
Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Apr 23, 2009 | Canon imageRUNNER 6000 Copier
Canon GP335 - error E001
E001 is a no heat error.Open and close the front door.If that does not work you will probably have to call a copier technician.Good Luck
Mar 27, 2009 | Canon imageRUNNER 210S Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Canon imagerunner 210s
EOOO is a thermistor-fuser error. Your machine will need a fuser, but on occasion a power surge can trip the error, E000 needs a code to reset it, I dont know if same but this is the code on a IR 330s
Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
You will now enter servicemode
press " Copier "
press "function"
press "Clear"
press "Error"
leave servicemode by pressing resetbutton twice.
restart machine.
Mind you it is only a reset, if fault still exist it will go eooo again confirming that it needs a new fuser unit.
Dec 30, 2007 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 210S Copier Logo
204 people viewed this question
old marine
old marine
