Question about HP OfficeJet 7310 All-In-One InkJet Printer
My HP officejet 7310 won't work
When turning power on, power light lights up but nothing else works. LED screen is black. di-di-di sounds when pushing ANY button. However, printer DOES print when copying from computer screen.
Took unit into HP rep store, Best Buy. They said they probably could not have it fixed due to no parts available. Please help/suggestions?
  • marcie87 Apr 25, 2009
    I have the same problem, What ever happened to your printer?
    Genius:
  • 2,120 Answers
If recycling the power doesn't work, it's uneconomical to have repaired.
Posted on Jan 25, 2009
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
How to remove a large black line in middle of
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Officejet 7310 APF up scans and copies fine APF down Paper feeds to glass and light goes half way then a gear sounds like it's spinning and then a message says turn power off then on again. Jerry
hi
it is a clear sign of harware ,,i would request you to get intouch with the harware technican who can open up the printer ,,,,,,because even i had the same problem
Jul 22, 2009 | HP OfficeJet 7310 All-In-One InkJet...
The machine is frozen, can it be fixed or time to replace?
Hi
We need to reset the printer, please follow the below steps to resolve the issue.
POWER DRAIN:-
Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-
Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-
Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-
Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks
Riz
Dec 29, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP 7310 it can not power off, got an error message. the machine does not work
Pull the power cord... if it does the same thing after plugging it back in it is probably toast.
Sep 29, 2008 | HP OfficeJet 7310 All-In-One InkJet...
We get power to the little screen and nowhere else
hi pls u check catridge holder circuit.. may be its geting damge or any hole printer doing like this... in this case no solution.. better u replace a machine.
Sep 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Power problem?
u better check all the flex cables etc normally it get damaged
thnx N
Jan 25, 2008 | HP OfficeJet 7310 All-In-One InkJet...
OfficeJet 7310 FAX issue
Did anything happen prior to the issue? It almost sounds as if the DC controller (main board) has gone bad. What happens if you try to make a copy on it?
May 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
117 people viewed this question
Ben Johnson
