Question about Xerox DocuColor 12 Color Copier
Docucolor 12 no print color & B/W
Hi, I forgot to mention that both color and B/W prints fine using the glass/copier. However, when I send the print job it doesn't work at all. No print but a blank paper. How would I fix this? Thank you for your help, Keith
  • 2 more comments
  • howsimple Jan 17, 2009
    O.K. I will wait for your response. Thank you very much! Keith
    One more thing. I have the EX12 Fiery.
  • howsimple Jan 19, 2009
    I was able to find the problem. It was a loose cable inside the copier. Thanks for your help.
  • oooimstuck May 11, 2010
    OK. That rules out a machine fault. I will get back to you if there is a patch for the fiery. I wouldn't hold your breath for an easy fix however
  • 62 Answers
The only thing apart from software corruption is that you could try printing a configuration sheet. If this prints then black printing is working. If it won't then print a test page then you need composite patch from the xerox "drivers and downloads" site. If none of this works it is a software reload.
Posted on Jan 18, 2009
Docucolor 12
check scanner unit which hit the opc drum, may be hide by something
Dec 27, 2013 | Xerox DocuColor 12 Color Copier
Docucolor 12 low density
cambia reveladores y reza un padrenuestro
Oct 31, 2009 | Xerox DocuColor 12 Color Copier
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
DocuColor 12 CopyCal
probably a reprint of page one to see if the adjustments are correct
Oct 29, 2017 | Xerox DocuColor 12 Printer
That happeng to me before, i just low the resolution that fix the problem or flat the image before you send that help too
Mar 18, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 2045 print White areas
a number of reasons can cause this. have you tried each colour individually? after this swap drums and see if fault moves with the drum. otherwise its probably developer
Jan 21, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 printing nothing from glass
The only fuses it could be are the 24v fuses going to the ROS. In general it would "normally" be the ROS and Halftone pwb or the Vsel pwb. Both of these might not be sitting right/loose ribbon cables etc, depending if you have been working in that area.
The other option is a defective cleaner clutch for the IBT. This "normally" leaves with just the black left on the print however. You will have to watch the machine and see if there is actually an image being produced on the drum. If not, the ROS (ROS and halftone pwb must always be replaced together)
Jan 19, 2009 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
Jan 18, 2009 | Xerox DocuColor 12 Color Copier
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
200 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
