Question about Uniden Cordless Phone
Loud noise develops after about 10 minutes or less talktime
It begins with a Thunk sound ever few seconds, then develops into a lawn mower sound which becomes deafening. Has to be back on hook for some time before can talk again. Could be the battery but do not want to spend my 89 year old Mom's money if it is the phone.
    Problem Solver:
  • 4 Answers
Have you tried switching channels? Could be that some kind of equipment in your home or nearby is interfering.
Posted on Jan 18, 2009
Was mowing the lawn about 20 minutes then mower stopped. It is a craftsman platinum 7.25
sounds like the spark plug may be fouled or the fuel filter or carburetor is dirty.
Sep 17, 2016 | Craftsman Garden
Lawn mower sopped running when I engaged blade.wont restart!loud explosive backfire 5 to 10 seconds when trying to restart. doesn't sound like normal backfire
sounds like the flywheel shifted. Was the blade bound up with grass or something? The Keyway on the Crank may have broken and the flywheel shifted. That would throw off the Timing
May 27, 2015 | Cub Cadet Garden
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Kickback
SOUNDS LIKE CARBON BUILD UP ON PISTONS, VALVES, HEADS....CAUSING BACKFIRE UNTIL SOME LOOSENS AND BURNS OFF
Sep 09, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
I was mowing the lawn, and I ran over a dirt *****. Now the engine will not start. It also sounds like something is loose inside. I hear a few clunking sounds when I pull the cord. Do I need to take...
Yoy can try tightening the blade bolt. i know it sounds funny but if the blade bolt is loose (or even alittle loose) the blade balance throws off the engine balance and can cause it to
1 not start
2 make loud clunking noises when trying to start
3 make a real racket if it does start
try flipping the lawn mower over and just tighten the bolt that holds the blade in place.
That should fix your problem.
Please dont forget to rate my answers
Thank you
Jun 17, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Lawn mower has a loud noise like something is hitting on metal part.changed blade this year with no problems. loud excessive vibration when running.
Sounds like your deck may be bent in and the blade is hitting. Remove the sparkplug and tilt the mower back on the handle (I'm assuming this is a push mower) and have someone pull the rope while you watch the blade underneath. You should see the problem.
Aug 06, 2009 | Craftsman Garden
Mower will not start. Makes a loud fast clicking noise when the key is turned.
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
May 10, 2009 | Toro Lawn Mower With Toro Power Tools
Samsung Side by Side Refrigerator RS2556SH - Making loud noise
Hi, had the same problem with my RS21DCNS engineer came and made a modification to drain hole (made the hole bigger!) this allows for a little more ice to form without causing the horrid noise. A new backplate was ordered as all new models have a larger hole in the backplate already. It only takes a few mins and it under guarantee if you bought less than 2 yrs ago, but you will have to empty fridge side to allow them to get to inside at the back. Good luck.
Sep 17, 2006 | Samsung RS2630SH Side by Side Refrigerator
Uniden Cordless Phone Logo
263 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
