Question about Brother IntelliFax-2820 Laser Fax
Brother mfc-8300 phone connection problem
When we use the phone part of the machine the connection goes "dead". If I wiggle the phone cord in the port where it is connected to the machine, it will then work. I have tried replacing the cord as well as using a different port, but that does not work. Any suggestions?
  • 186 Answers
Make sure the line from the wall is plugged into the port marked"line" and not "phone" If this does not solve it then it sounds like there is a loose solder joint on the connector inside the machine.
Posted on Jun 21, 2007
Can not send outgoing faxes on brother mfc-8220.
There are a number of reasons why you may not be able to send a fax. Check your manual for troubleshooting tips. However here are some simple things to try.
1. Check to make sure the cord from the outlet in the wall to your all-in-one is plugged into the proper port. There are usually two ports that will accept your phone plugs on the back of machine. One goes to your phone or answering machine and the other one to the line that goes the outlet in the wall. It's easy to plug your cord into the wrong port. Try plugging your phone cord into the other port and see that works.
2. You may have a defective phone cord or the wrong type of cord. Most phone cords only have two conductors in the cord and others have four. Try replacing the phone cord with a known good phone cord and see if that helps.
Oct 11, 2013 | Brother MFC 8220 All-In-One Laser Printer
How do I fix a machine error 78 on my brother MFC 8300?
unfortunately that specific error is pointing to a problem with the thermistor. here is the error code from Brother:78 Heater thermistor harness disconnected or broken. - SOLUTION: REPLACE FUSER UNIT
HERE is a link to other error codes and possible solutions.
Aug 30, 2010 | Brother MFC 8300 Laser Printer
How do I clear the memory on my Brother MFC 8300?
Un plug machine count to 10 than re start unit. this model dose not have battery back up. should clear all settings.
Aug 11, 2010 | Brother MFC 8300 Laser Printer
Brother MFC 8300 Laser Printer to print documents front to back
there is a option duplex printing in print option find and try it. it will solve your problem.
Apr 08, 2010 | Brother MFC 8300 Laser Printer
When I plug my fax into the phone line, my phone line goes dead to all other phones. Never had this happen before. Help
make sure the fax machine slot is not short .remove all the parale line connection and just conncet the fax in to line and check you are gettting the dial tone.
Jan 14, 2010 | Brother MFC 1950MC Printer
Don't know how to connect with phone and computer
USB Cord (Included with Printer) ---Connects to PC (computer).
Phone Line Goes From Wall To Printer (For Fax)
There Should be a seperate jack for both Line-In/Fax....and Phone......The Phone goes out to your phone handset
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
MFC 7420 always say toner low after you change new toner
If you are using the MFC 7420, then you should see the option buttom just next with the LCD. press the option and hit 00. then the message will just go away.
Feb 10, 2009 | Brother MFC 8300 Laser Printer
Brother MFC-7840W fax will not work
Plug a regular phone into the wall jack and listen for a dial tone.
Phone cord should be connected to the LINE port of the fax.
Do you have DSL?
Unplug power cord for 10 seconds.
Oct 17, 2008 | Office Equipment & Supplies
Hand set goes dead
Next time it goes dead, try wiggling the cord where it plugs in the handset and where it plugs into the phone. If the problem goes away, you will need a new cord.
Hope this helps, and if so, please rate my advice.
Feb 05, 2008 | RCA 25202RE3 Corded Phone
Fax machine
Replace the fuser. Easy job.
Dec 11, 2007 | Brother MFC 8300 Laser Printer
Brother IntelliFax-2820 Laser Fax Logo
37 people viewed this question
James Cagle
James Cagle
Jim Keysor
