Question about HP OfficeJet 9120 All-In-One InkJet Printer
PRINTER ON/OFF WHEN TURNING PRINTER ON A MESSAGE HAS COME UP SAYING PRINTER ERROR TURN OFF AND THEN ON, I HAVE TRIED THIS SEVERAL TIMES AND EVEN LEFT IT OFF FOR 24HRS, I HAVE CHECKED PAPER AND REPLACED INK CARTRIDGES BUT NO JOY, HELP PLEASE, CANT SURVIVE WITHOUT THIS WORKING!!!!!!
    Scholar:
  • 47 Answers
Op the ink cartridge protective door located above the ink cartridges. remove both cartridges. look at the white ribbon cable that connects to each cartridge. You will see gold dotted connections. look closely for a small hole in the cable . This hole is caused by the spring that holds the cartrdges in. Sometimes people force the cartridge in puncturing this ribbon cable. It is a poor design by HP . The error code will usually say ink cartridge door not closed. Unfortunately the assembly is fairly difficult to replace and can cost as much as to printer. If you bought new cartridges, buy asimilar unit which uses the same cartridges. Then at least its not a total loss. Scrivitron
Posted on Jun 19, 2007
SOURCE:
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
I have a Toshiba EStudio 3511. It is giving a message saying Service Required. I hit clear and number 8 and I get error code F070. How do I fix this? I tried turning it off and on several times even from...
f070 communication error between system cpu and main cpu
firstly try updating the firmware version
then possibly replace the system board and or lgc board good luck
Mar 23, 2011 | Toshiba E-STUDIO 850 Copier
Open Door
Hi, here is something that you can try http://bit.ly/bHHnnO
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
Hp laserjet m1522nf
Copy function was not working, says "device is busy". Message appeared on the printer screen is:"scanner error 5, turn off then on". This was done several times and message still appeared. I called 866-625-1176 and was connected with HP Technical Support and after 20 - 25 minutes of diagnostics, the technician informed me that they were sending me a new printer at no charge. I assume this meant that HP is aware of the defect and has no solution other than to replace it. The printer was only 6 months old.
Sep 05, 2008 | Office Equipment & Supplies
My HP Officejet 7410 All-in-One keeps giving me the error message - Scanner failure - Turn power off then on. Turning power off then on, even disconnecting power cord, repeatedly does not solve problem.
Our HP Officejet L7780 displays the "Align Printer" message and then does it automatically wasting several sheets of paper aligning, then the next time we print a page the same message comes back. Is there a way to turn off the "align Printer" message. It is printing ok otherwise.
Jul 31, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP OfficeJet 9120 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
