Question about HP RT810UTABA - HP dc7700 small form factor, Core Duo E6300, 80GB hard drive 7200 SATA, no floppy, DVD/... PC Desktop
Finding it difficult to install a second hard drive on hp dc7700
I have an h[p dc7700 sff and I am trying to add a second hard drive as the one it came with has virtually run out of space. I do not know exactly where to plu the second one in as there is a spare power cable for it but cannot find a spare data cable. Currently I have 80 GB and is trying to install a 300 GB.
Can you please help me.
Thank you.
  • 1 more comment
  • joseph_sakyi Jan 16, 2009
    Apparently, there is a slot for it. I have taken the data cable from my optical drive and connected it to the second drive and it is working perfectly. I think what i need is another data cable for my optical drive as the motherboard has got a spare slot for it.
    The only snag is where to get another data cable.
  • ZachG85 May 11, 2010
    i just looked at a picture of this computer and I don't believe another hard drive can fit (not sure because i only saw a picture of the front)
    there are two directions you can go with this:
    1) replace the old hard drive with the new one.
    2) add the second hard drive for storage purposes
    to do the first you would need to clone your old drive, if this is what you want i can try to walk you through it. the first thing you want to do is chase the cable running from your old drive and tell me if there is another port available.
    for the second i would recommend getting an external enclosure for the drive that you can plug in via usb
    example: http://www.newegg.com/Product/Product.as...
Http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10226&cs_id=1022602&p_id=4863&seq=1&format=2
Posted on Jan 16, 2009
    Genius:
  • HP Master
  • 1,102 Answers
Some older sytems don't have the option to add a second hard drive
can you save your files on cd's or travel drive and then install the new hard drive
  • DEKR
    DEKR Jan 16, 2009
    your tellin me you can't remove your old hard drive and use those cables
  • DEKR
    DEKR Jan 16, 2009
    you can usually buy the data cables
    i would get it from a small pc repair outlet
    you'll get it cheaper
Realtek audio set up on HP dc770 Core 2 duo E6400 PC
plug in the appropriate plug and use fix it center for help
Mar 11, 2012 | HP GC402AWABA - HP dc7700 SFF E6400 160G...
Ethernet driver missing on hp dc7700cmt computer. I have tried to use the drivers form the HP download site but the driver still comes up missing. I can't connect the computer to the internet to let...
Open the Device Manager (you can do a Windows search for it if you don't know how to open it).
Look in the Network Adapters section.
Remove your Ethernet device. Right-mouse-click it and make sure it's not disabled. If it's disabled, enable it and you should be fixed.
Otherwise, click it to highlight it and press "delete" to remove it. Then right-mouse-click on "Computer" (at the top) and "scan for hardware changes." Windows *should* install the correct driver.
Otherwise you'll need to go to the HP support site on another computer, save the driver to a flash drive, external hard drive, or CD or whatever, and then install that on your computer.
Jan 03, 2018 | HP-COMPAQ DC7700 CMT C2D/2.4 2GB-160GB...
I have a HP Compaq d530 SFF with a 40 G hard drive. I want to upgrade to a hard drive of at least 80 G. Am I able to do this? Like to know also how much more RAM can I add I have 1.5 GBs now..
You can get a maximum of 4GB of ram.
Yes you can also upgrade your drive, probably to a lot larger than 80.
The following is a link to the manual that you can download, in PDF format, that has information on upgrading/adding both memory and hard disks for the HP d530 SFF. It has both diagrams and instructions.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00059123/c00059123.pdf
Go to the "Hardware Upgrades" section.
Feb 11, 2011 | HP Compaq d530 SFF PC Desktop
I would like to move it in to a bigger case
When looking at the specifications of the HP Compaq DC7700 SFF Desktop PC, all they state is the motherboard form factor is, 'Custom'.
Same thing for the DC7700 USDT Desktop PC.
Both of these desktop computers are of the 'Pizza Box' design.
(Flat rectangular box)
The DC7700 CMT model is a tower model, and the motherboard form factor for it is uATX.
uATX can also mean Micro-ATX.
The form factor of a Micro-ATX motherboard is 244mm by 244mm, or also said as 9.6 inches by 9.6 inches.
(9.6 inches is approximately 9 and 9/16ths inches)
To regress for a moment, and explain the term Form Factor.
This term is supposed to apply only to motherboards, but has gone on to apply to computer cases, and power supply's.
Form factor means the dimensions of the motherboard, and also where the I/O area is located.
[I/O = Input/Output
Area for the Input/Output devices that are attached to the computer.
Examples: Mouse, Keyboard and Monitor]
Whether the motherboard is installed onto the Left side of the computer case, and the I/O area is on the Left side also (ATX , Micro-ATX, and uATX form factor),
or
whether the motherboard is installed on the Right side of the computer case, and the I/O area is on the Right side also. (BTX)
Dimension sizes:
ATX is 305mm x 244mm. (12 inches by 9.6 inches)
Micro-ATX is 244mm x 244mm (9.6 inches by 9.6 inches)
http://en.wikipedia.org/wiki/Computer_form_factor
Above the link is the Maximum size for the Micro-ATX form factor.
It can also be the Minimum size of 171.45mm x 171.45mm
(Or 6.75 inches by 6.75 inches.
6.75 inches = 6 and 3/4 inches)
http://en.wikipedia.org/wiki/MicroATX
Point of all this?
The motherboard form factor inside a DC7700 SFF is probably a uATX form factor, and is 6.75 inches by 6.75 inches.
Or some variation thereof.
It's a custom size.
This means good luck in finding a computer case you can buy off of the shelf, and is large enough to install an ATX power supply.
You can get a custom one made, and you're probably looking at $150 to $200.
Or, you can modify one of these computer cases VERY easily,
1) http://www.directron.com/cs888uvbl.html
The above is an Acyrlic plastic computer case. It's approximately 1/4 inch thick for the case walls, bottom, and top.
VERY sturdy.
It has metal Standoff's that are set up for an ATX motherboard.
It should have holes in the case where a Micro-ATX motherboard can be mounted, by unscrewing the Standoffs, and screwing them into the Micro-ATX holes.
[A Standoff is a piece of metal that is hex shaped, and has a threaded hole in one end, and a threaded end on the other side ]
If there isn't the proper holes for mounting your motherboard, you make the holes.
The case is plastic.
Uses an ATX power supply.
The cost of the case is $50
Mar 08, 2010 | HP RT810UTABA - HP dc7700 small form...
D530 sff hard disk & cd drive update error
hi,
you must be do the default setting into BIOS SET UP so that the hardware you add can detect into it...thanks
Nov 22, 2009 | HP Compaq d530 SFF PC Desktop
Hp dc7700 small form factor
Do you have high speed internet?
Then you do not need the built in modem
Click on Start>Control Panel>Internet Options>
Connections and put a dot beside the line
'Never Dial a Connection'
Click apply and then ok
Now open Internet Explorer and try to surf.
Mar 15, 2009 | HP RT810UTABA - HP dc7700 small form...
Hp dc7700
verify you device manager if there is modem or network card installed, if you see a device with yellow question mark..it means you need to install the right driver
network card are built in to motherboard...maybe the right driver is not installed.
you can verify the original configuration by going to hp web site support and type the product number..
HP RT810UTABA - HP dc7700 small form factor, Core Duo E6300, 80GB hard drive 7200 SATA, no floppy, DVD/... PC Desktop Logo
739 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
