Question about LG 50PX4DR 50 in. Plasma TV
50 lg plasma turns on then off again
I have a 50 lg plasma (mod#52lg50) When you turn it on the green light comes on then it clicks and will turn right back off and the light goes to red.Hope you can help before I have to take it to an expensive repair shop.
  • 2 more comments
  • Anonymous Jan 27, 2009
    Sometimes this happens upwards of 100 times. Unplugging and plugging doesn't do anything. Nor does pressing any buttons.
  • Anonymous Feb 21, 2009
    Having exact same problem with 50inch LG
    I have the LG 50PC1DRA and have the same problem today.
  • whitehouse25 Mar 15, 2009
    We have a 50PC1DRA. When turning on, the green light blinks several times, then goes solid briefly; the picture will flash on briefly then turn off will a audible pop. Power light goes back to red.
    Previously, after several repeats of above, the picture would finally stay on. Now it won't. Please help !
jerryg50
  • 1673 Answers
SOURCE: 50 in LG turns on and then clicks and turns back off
The power supply is going in to protect mode. Most often this is a power supply failure, or a failure on one of the circuit boards that is causing the power supply to go in to protect.
If the power supply fault is not too complicated an experienced tech may be able to service it without changing the compete circuit board.
The tech will service this by substituting boards to determine where the failure is occuring. Then he will change the board to fix the fault.
Jerry G.
Posted on Feb 10, 2009
zjut
  • 106 Answers
SOURCE: LG 50PX4DR plasma tv
Open the back cover and check the fuse on YSUS Board. If the fuse was gone, replace the YSUS board or ZSUS board.
Posted on Jan 14, 2008
  • 5 Answers
SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Posted on Jun 03, 2008
  • 1335 Answers
SOURCE: Power light turns green but no picture or sound
Is the system set to the correct input source?
Was anything done to the setup before this started happening.
Posted on Apr 29, 2009
  • 8457 Answers
SOURCE: my LG 42
Ur video inverter controller is dead,the board between the power supply board and main video backlight board.
Posted on Oct 14, 2009
My LG 52lg50-ua lost audio and video after x-box1 was plugged in. The back lights are still working, looks to have voltage at the marked terminals on the power board
Check and replace the damaged component/s at its main board.Contact any service technician.If you wish to get some details; check the site linked here.Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 21, 2014 | LG 50PG20 50 in. Plasma HDTV
My Zenith plasma TV blinks green 4 times then goes red, No picture. None of the Capasitors are blown.
I had AWFUL customer service. (Sherry is DREADFUL her # is 1-877-543-8325 she is in"executive services". Ask to speak to her directly...if you would like ZERO help.)
They WILL NOT extend the warranty, even though they know there is a defect with this AND other models. Zenith name on the front...LG guts in the inside.
Ours turns on, screen black and then clicks three times and then turns back off.
Jul 13, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
No display issue
Red means it is going into shutdown because something is wrong.
It will not come on again until problem is found and corrected.
What is model number and do you have a warranty?
Mar 12, 2012 | LG 50PS60 50 in. Plasma HDTV
I have an lg 52lg50 lcd tv. for some time now the switch just repetitively clicks until the tv eventually comes on. the last couple of days, it doesn't come on at all - it just carries on clicking. is...
Hi, I've had that happen with TVs before, it tends to be caused by blown capacitors on the motherboard. It can be fixed however it's not something you could easily do on your own, you'd want to take the TV to a local repair shop, I've seen the repair range from $50 up to $250 or so in my experience.
Aug 29, 2011 | LG 52LG50 52 in. LCD HDTV
Turning on tv on a morning is a night mare led is on red press remote light goes off for about 20 mins then comes back on try turning on again goes to green light for 20 seconds then turns off again this...
usually is an issue with the power supply or power inverter for the tv. basically one of the capacators is not holding a charge like it should and is causing the power to drop. contact a repair technition or begin looking for a new tv.
Mar 07, 2011 | LG 50PG20 50 in. Plasma HDTV
Hi there I have a lg 50pc3d plasma. It does not turn on. When I power it up it clicks and then clicks again and Turns off but the red light on and when i press TVinput or input and channel up/down from...
Power supply board is dead.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 10, 2010 | LG 50PC3D 50 in. Plasma Television
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
Sep 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
LG 50PX4DR 50 in. Plasma TV Logo
724 people viewed this question
Computer Repairing
Computer Repairing
