Question about Apple MacBook Pro PC Notebook
Screen has blue tint and the computer is making a wierd noise
I was not able to login with my regular username and password. I had to go through a dos based section to be able to add a user as the install cd change password utility did not work. During the setup for a new user the computer would not take my MAC security login for my router but it did take the security password for a pc which was totally strange because the system was set up before using the MAC security login.
Once in the was a prompt for updates. So I decided to let the computer install the updates. After about five minutes of installing the updates the screen changed and went weird. Hard to read and there was a blue tint and very pixilated. I tried rebooting the computer but that has not helped.
  • crhansen Jan 17, 2009
    It is a MAC OS X 10.4.6
    Originally only one. But the password stopped working. I did a search and found that if you put the install cd in and hold the option's button down you can go to utilities to reset the password. I did that but the new password would not work at all
    When the password reset did not work I found the option to hold the control and s button down to go to a dos based part and be able to add a user. I added one user and password and restarted the system as the directions stated. I was able to get in and it seemed to work fine until I started running the updates. The first update was a java update and in the middle of that one the screen went all weird. I finished running the updates and did two different virus checkers and a malware/spyware checker. All came up negative. So I added my daughter as a user to test the system and her login seems to be fine.
  • bchadra May 11, 2010
    How many users are configured for the PC? Is it checked regularly for viruses and rootkits? What type of OS is installed?
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords
Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next?
Login to Your ZyXEL Router Using the Router Password
Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: ===============
Forgot Router Password?
If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings.
What should you do?
Login to Your Router Using the Default Router Password
Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides.
Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!)
Find Your Default Router Password
Simply select your router manufacturer from the list below to display the default router passwords and usernames.
Nov 02, 2014 | Zyxel Computers & Internet
Tip
How to Break Windows Administrator Password from DOS Command Prompt?
<p>A windows administrator account is a user account that gives full access to the machine. It is by far the number one target for someone trying to gain illegal access to your network and resource. So Administrators should change administrator password frequently to avoid unauthorized access to the domain or desktop machine. <br /> <p><br /> Then something bad happens. Password can be easily forgot or lost. If you <b>forgot windows administrator password</b>, how could you <b><a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">break windows administrator password</a></b> and gain access to your admin account?<br /> <br /> <p><br /> Here is how to break windows administrator password from DOS command prompt</b><br /><br /> <ol> <li>Login as administrator or user account that has administrator privileges.</li> <li>Click <b>Start</b> -&gt; <b>Run</b> </li><img src="click-run.jpg" /> <li>Type <b>CMD</b></li><img src="type-cmd.jpg" /> <li>Then the DOS shell screen will appear like below, Type "net user username password/domain" into the command prompt.</li> <p>Replace username with the user account you login and the password with the new password you want to assign to that account. /domain is optional. If you are in a domain, specify the domain otherwise leave it.<br /> <li>Once you click<b> Enter</b>, your password will be changed, like the example, the administrator will change the password of the user Michelle to 123456.</li><img src="net-user-password.jpg" /></ol> <p><b>NOTE: </b>If you do not have administrator rights on the machine, you will get the error message stating "System error 5 has occurred. Access is denied." <br /> <p><br /> If you receive this error message that means you couldn't <b><a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">break windows administrator password</a></b> from DOS command prompt. At this time, SmartKey Windows Password Recovery comes in hands.<br /> <p> <br /> <b>SmartKey Windows Password Recovery</b> is a powerful password hacking which can help to break Windows administrator and domain password by burning a bootable <b>Windows Password Reset CD</b>/DVD or USB flash drive. With this bootable password reset cd, breaking windows admin password is a child's job.<br /> <p><br /> Here is how to <b>break windows administrator password </b>with Windows Password Recovery </b><br /> <p> <br /> Step 1: Download and install SmartKey Windows Password Recovery software.<br /> Step 2: Burn Windows Password Recovery software to CD/DVD or USB flash drive.<br /> Step 3: Breaking the lost or forgotten windows administrator password.<br /> Only need 3 simple steps. Your windows administrator password has been broken.<br /> <br /> <p><br /> <b>Contact:</b><br /> Official Website: <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">http://recoverlostpassword.com/products/windowspasswordrecoery.html</a><br /> Email: <a href="mailto:support@recoverlostpassword.com">support@recoverlostpassword.com</a> <br /> <p> <br /> <p><b>Related Article:</b><br /> <a href="http://recoverlostpassword.com/article/break-word-password.html"><img src="jiantou.gif" /> How to Break Word password</a>?<br /> <p style="font-weight: bold;"><br /> <p style="font-weight: bold;">Article Source:<br /><a href="http://recoverlostpassword.com/article/break-windows-administrator-password-from-dos.html">http://recoverlostpassword.com/article/break-windows-administrator-password-from-dos.html</a><br />
on May 24, 2011 | Computers & Internet
I can't log in to my account on my Dell PC?
Now which operating system are you running ?
Forgetting your Windows XP login details might at first seem like a disaster. Don't panic though; your login password and username are easily recovered by changing the login details to that of the administrator.
Begin with your computer turned off, and then turn it on. You will need to log in to your computer manually and this can only be done in the load-up screens. Wait until your computer reaches the Windows login screen. The screen usually displays a "Welcome" message. Press and hold the "Ctrl", "Alt" and "Delete" keys two times at the Windows login screen. Your computer will automatically reveal a Classic Login box. Type "Administrator" (without quote marks) into the "Username" field and leave the "Password" field blank. Windows automatically creates an Administrator account when your computer is first booted up; in this account you can alter or change any user's login details. Navigate through the "Start" menu and click on the "Control Panel." In the Control Panel explorer, double-click on the "User Accounts" icon to open a new window. Select "Change an Account" in the User Accounts window and select the username you want to alter. From here you can edit the user's name and password, but you can also alter the user's picture, account type and .NET password. Restart your computer to login with your new username and password.
b>
Apr 10, 2013 | Dell Computers & Internet
FORGOT CODE, TRIED THE WRONG 1 TOO MANY TIMES AND NOW ITS LOCKED
try pressing CTRL + ALT + DELETE a new window will appear enter administrator as username then press ok,this will login provided that ur administrator account is not locked.Otherwise follow the below Step:
u can use active boot disk to reset password and unlock ur computer
here is the url:
http://download2.lsoft.net/boot-cd-iso.zip
u need to write this image to cd using the toll came with it to make it dos bootable and then u hv to boot using this cd.
u will find password recovery tool there which will delete ur password so that u can login. reset password and then boot with ur harddisk.Now u can login.
Mar 17, 2010 | Computers & Internet
Cant get in to my computer lost my password
If you can tell me what the Os do you use, it could be must better.
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password reset tool. I recommend Windows Password Reset.
Resource: http://www.windowspasswordreset.net
Nov 05, 2009 | Acer Windows Vista TL-562G Notebook
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Dont have username and password need restart
You can use the following steps
1. Restart your computer
2. Tap on the F8 key slowly 5 times on the Blue Dell logo screen
3. Select safe mode from the screen
4 Hit enter
5 When you see the windows login screen Click on Adminstartor account
6 Click on Yes
Once you have logged into the adminstartor account
1. click on start
2. Click on control panel
3. click on user accont
4. You can change the password for the exiting account or create a new account
If you are not able to login to the adminstrator account aswell beacuse of the password, the only option would be to reinstall the operating system from the windows xp cd
Thanks
Proton
Apr 08, 2009 | Dell Latitude D400 Notebook
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
TravelMate 2480 Password to LogIN?
You might boot up your computer and start pressing the f8 button for a couple of times. It now boot in Safe Mode and you will see some strange information running by your monitor.
After that there will appear a login screen that requests a username and password.
Try to fill in the username as administrator and leave the password area blank.
You might be able to log on to your system now and than you can change the password of your regular account by browsing to start -> configuration -> users and select your account followed by clicking change password.
I hope this will solve your problem
Jan 30, 2008 | Acer TravelMate 2300 Notebook
Cannot get into my computer at all
There is probably some other utiliity running ..Have u tried pressing the f8 key while the computer is starting up. this should take you to the option of starting in safe mode....
Apr 30, 2007 | Dell Latitude C640 Notebook
Apple MacBook Pro PC Notebook Logo
268 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
