CD stuck in a Poly-Planar MRD-60
I received an MRD-60 Marine Grade AM/FM CD Player Stereo as a gift about 2 years ago. It has been sitting new and unused in its box since then. I just connected it to a +12VDC power supply to test it out. I put in a CD but it did not get pulled into the unit. I pushed it in the rest of the way but it would not play. I push the ''Source'' button to select the CD player, but it just keeps playing the FM radio (every so often the word ''eject'' will quickly flash when I push the button, but then it just goes back to the radio). The CD ''Eject'' button on the inside panel does nothing when I push it. The FM radio is all that is working. Any suggestions on how to get the CD out and how to get the CD player to work?
SOURCE: cd player buttons don't work
i suggest flipping the "hold" switch, just in case.
Posted on Jul 25, 2007
simplemitch
  • 752 Answers
SOURCE: CD Player not playing any audio CDs
The laser is damaged or dirty. Try gently swabbing the lens with rubbing alcohol and drying with canned air. If this fails the laser is damaged and unrepairable.
Posted on Sep 12, 2007
SOURCE: 2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Posted on Dec 02, 2008
SOURCE: Magnavox Jogproof Personal CD Player - says HOLD
there is a switch that locks all controls
Posted on Mar 01, 2009
SOURCE: Personal CD player doesn't power on
There was another post suggesting a novel approach. He said to shake player vigorously a couple of times or drop it from about 2-3 feet on carpet (without a cd in it). I did both. It worked for him and to my amazement --- it worked for me too on a SpongeBob personal cd player. What do you have to lose? Good luck.
Posted on Mar 11, 2009
Audio solutions am/fm/cd digital stereo where is the battery compartment
There is no battery compartment on it, It has to be install in a vehicle in order to work.
Oct 16, 2012 | Dual MXD-60 Marine Audio AM/FM CD Player...
Nad 7140 fm low frequency hum
This is probably a 60 cycle hum and the problem is more likely confined to the am/fm board, there is a bad ground due to poor solder joints, broken ground wire, an open capacitor, this may not be easy to find, but it is a start.
Apr 22, 2012 | NAD 7140 Stereo Receiver With Phono Input
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
May 31, 2010 | JBL Am/Fm/Cd 180 Watt Marine Audio System
Red,yellow and blue with stripe hooks to what into harness
some decks have a solid blue for power antenna and blue with white stripe for amp turn on. if you have neither a power antenna or amplifier, i would not worry about connecting those two wires. do makes sure they are capped off and have no bare wires showing, as they are hot when the stereo is turned on.
May 05, 2010 | Pioneer DEH-P2900MP CD Receiver...
Security feature problem on car cd deck
i have never seen a jvc that required a security code. it is possible that you may have a bad power or ground connection if lights are blinking off and on. sometimes when a deck has been sitting for a long time capacitors may dry out.
Apr 13, 2010 | JVC AM FM CD DET FACE CAR STEREO
SEA2300 +ESP - cd disc stuck in player
disconnect the power and open the side where the cd motor is and remove manually
Jun 20, 2009 | Sea Worthy 9001G Marine Casseiver...
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
134 people viewed this question
 Grubhead
Grubhead
