Hi, Sombody has got the "BWI 715 Super G wireless driver (Blitz)"? Could you please send me a copy? Thanks in advance Sier
It turns out the BWI 715 is the same as the D-Link 520 Rev B. http://support.dlink.com/products/view.asp?productid=DWL%2DG520%5FrevB# Select that as the driver and it'll work.. D-link even has Vista support so you might be able to get it to work in Vista. They share the same FCC ID KA22003070025-1 Which means they are identical in every way.
I have uploaded an ISO image of the full installation disc here:http://www.fileqube.com/shared/xZVVPd102180
simply burn the image to a cd and you're ready to install.
I got this to work on Windows 7 - 32 & 64bits by downloading the drivers directly from D-LINK. It uses the same hard ware as the DWL-G520 rev 5. Here is directly link to D-Link download website.
http://www.dlink.com/products/?tab=3&pid=DWL-G520&rev=DWL-G520_revB
Your driver can be downloaded here: http://www.soft32.com/download_174686.html Or here: http://members.driverguide.com/driver/detail.php?driverid=769150
Try this one it worked on mine. its for the driver not the program.the drivers dont work on vista so far http://members.driverguide.com/driver/detail.php?driverid=432545
SOURCE: BWI 715 Super G wireless driver for Windows
I have the original CD Drivers, If you want I can share it with you.
Jimmy.
All you should need to do is to Discover available wireless networks on the machine with the Blitzz card in (it should be able to discover the belkin Wireless router)
you should have a wireless utility program that came with the card that lets you alter the configuration so that you can connect to this different router.
yes im afraid i do i would definetly apreciat the help on gettin the driver on the bwi 715
sofware driver
need driver
