Question about Toshiba Satellite A205-S4617 Notebook
Toshibas laptop A205 keeps shuting down
My computer is about 1 year old and it was working well, till a month ago now it constanly shuts down
  • lady0311 Jan 21, 2009
    I have the same PC, and have only had mine for about 7 months. It shuts down after only about 30 minutes of use. I have a digital gauge to tell me when it's hot, and it isn't when it shuts down. I have Windows Vista. This is really annoying.
    Sergeant:
    Champion:
  • 256 Answers
Its virus problem reinstall windows....
Posted on Jan 16, 2009
The computer shutdown, thught it was the power cord. Ordered new one, does the same as old one. Belw the tough pad blue light blinks power cord plug in, and I can't turn it on.
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my pc keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Nov 11, 2010 | Toshiba Satellite A205-S4617 Notebook
My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.And from yestarday it is shetting down after 30seconds after...
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
I decided to use a shop vac to suck the dust out and it worked. I tested it by letting the machine run all night and it worked. It's been a couple of weeks now and I'm glad I did it. I was ready to take the machine apart, now I'm glad I didn't. I'd suggest you use a heavy duty shop vac to clean out the fan and heat sinks first.I agree. Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Toshiba Satellite A15 Clogged Heatsink
Toshiba Satellite A35 Clogged Heatsink
Toshiba Satellite P15 Clogged Heatsink.
Aug 25, 2017 | Toshiba Satellite A205-S5855 Notebook
Satellite a205 died. will not power up at all. 2
Go to the Toshiba web site. They often extend the warranty on laptops with common problems.
Jan 09, 2010 | Toshiba Satellite A205-S4617 Notebook
It crashed and now it automatically shutdown after a minute about
The fan may be cluttered with dust. Clean it. Then turn the unit on and watch to see if the fan does indeeed work. If it does not, shut the unit down till you get a replacement fan. The fact that the unit shuts down is a saftey feature to keep your Proceesor from being damaged.
If cleaning it works, your processor should be ok.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 13, 2009 | Toshiba Satellite A205-S5879 Laptop
Toshiba Laptop A205-S4577 won't start up
If the battery is removed, it should still start up with the charger connected. A lot of laptops develope problems with the jack where the power supply plugs in, from constantly plugging & unplugging the charger. The jack in the back of the computer is probably bad.
Jan 15, 2009 | Toshiba A205-S4577 Notebook
Toshiba flash cards " not Responding"
Dear Sear
First of all i aprechiat your willing to offer me a solution for the problem (flash cards are not responding).My laptop has thise model; Toshiba Satellite A200 - 1 GB - intel(R)Core(TM)2 CPU T5300 @ 1,7 MHz.
I solved the problem just with shuting down the mashin, that's all.
I thank you indeed for you respond and i'm looking forwards.
Best regards
Yours
Aweti.J
Aug 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Battery not charging...
My impression is that you might have a defective cord if you still have your old adapter and has the same power specification try this first.
If the battery is hot and does not charge you might have a defective battery . Better have it checked at the service center before buying a brand new battery
Jun 23, 2008 | Toshiba Satellite A205-S4617 Notebook
Spontaneously shut down
coolers are working?
on 3 months is a short time to get dusty but i see laptops after a half year whit coolers busted from heavy dust,
May 06, 2008 | Computers & Internet
Computer Keeps Shuting Off/Battery is Useless
Try running a good malware program like AdAware. Often these spyware programs can driver your processor to 100%, causing it to heat up too much and shutting things down. Once you have the anit-spyware loaded, bring your system up in safe mode. This will allow the spyware to search the hidden partitions on your fd, along with the rest of the disk.
R-.
Oct 18, 2007 | Toshiba Satellite M45-S355 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
