Question about Xerox Phaser 6110MFP All-In-One Laser Printer
Xerox 6110 MFP not picking paper from tray or manual feeder
Hi, had this printer for some time now, generally happy but now having serious paper feed problems.
It's impossible to get paper in from the tray now, the only way to get paper in at the moment is to feed it manually but there is a knack to it and it doesn't always work. very frustrating.
When I slide paper into the manual feed the paper grabs it ok and sucks it in part way and holds it with 2-3 inches sticking out (all ok so far). The problem arises when it's ready to print and tries to take the paper in further, it has 2-3 goes at it and gives up. The only way I have been able to get round this is by waiting for this 2nd step and as it tries to grab the sheet I take hold of the part of the paper tray sticking out and move it up and down rapidly sometimes violently at which point the paper either gets taken in ok (30% of the time) or it stops as before and starts bleeping. Even if it does get 'grabbed' and moves further in it often gets in only 2-3 inches more and then stops unless I keep shaking the paper tray up and down for the entire print. Trouble is I can only do 1 sheet at a time like this and often have to spend 30mins+ on a 2-3 pages doc.
I've looked underneath whilst it's going through this process and I 've noticed that the large central rubber 'picker' which pulls the pages into the machine itself does not rotate anymore. It is a metal/white plastic rod with an 1-2 inch wide central picker in the middle which only has half it's curved 'contact' surface covered in rubber.
I'm at the stage where I'm probably going to open the machine up and try to get to the ends of the rod so that i can see if there are any obvious broken 'gears'/moving parts.
If there is an online service/repair manual for this machine I would appreciate a nod as to where it may be, I've looked at google and haven't seen anything and no-one seems to have a solution to this problem.
Really would appreciate any help with this, my back's killing me!
Cheers
  • sharpie2009 Mar 14, 2009
    I have the same problem with paper pickup. I was able to temporarily resolve by loading the paper with a bend (ie setting holders too short so that paper buckles). This seems to force each page into the feed as it is released.
    The problem however now appears to have spread to the rollers at the exit point. They have stopped rotating, meaning that although the paper is being grabbed & printed ok, it can't feed out and jams.
    Is anybody aware if there is a band linking these rollers that may have come loose and if so, how do I access it?
  • 71 Answers
Sounds like you need the pickup roller & separation pad replaced
Posted on Jan 16, 2009
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
The printer keeps saying there is a paper jam at tray 1 but there is no jam
It is not picking up the paper. You need to either clean or replace the feed roller on tray 1
Jan 16, 2011 | Xerox Phaser 6110 Laser Printer
My dell mfp 1600n will not feed paper without jamming in the auto feeder...what is wrong?
if the problem is with the paper from tray, suspect the rubber tires on the pick rollers are bad. You can remove them and flip them inside out and reinstall
Dec 31, 2010 | Dell 1600n All-In-One Laser Printer
I get a paper jam every time I use my Xerox 6110 MFP Printer. It jams on every document while printing or copying.
same problem here expert at Xerox adviced to clean black rollers on the papertray
maybe it works for you, not for me though ;-(
Aug 11, 2010 | Xerox Phaser 6110 Laser Printer
Phaser 7300 jamming manual feed
Can you print fine with no jams from the lower tray?
make sure you have clean new paper and start out with the 11"x8.5' letter paper. If you have that then follow the instructions below.
  1. Make sure there is no peaces of paper jammed in the path.
  2. clean the rollers with regular rubbing alcohol sometimes the rollers get way dirty to pick up the paper.
  3. If none of these tricks helped you then you have to change the the manuel feeder. part # 116-1561-00 good luck.
Dec 07, 2009 | Xerox Phaser 7300DN Laser Printer
Xerox 7132 noise when picking up paper from bypass
there is either paper stuck around a roller (3) that feeds the paper or you have a bad clutch, most mnfs use magnetic clutches at the rear of the machine or bypass that get a red rusty dust in them causing squeal. recommend xerox takes a look...sorry they are quite expensive hourly
Aug 04, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Can I disable the lower print tray?
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
May 21, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Xerox phaser 6120 colur laser printer
Not sure how long you have had that machine. But remove the paper and the tray. Dampen a slft cloth with some soapy cleaner, such as fantastic or Formula 409. Look into the paper feed area for the rollers and clean them well. Maybe 2 or 3 times. Then if you have some handy wipe them again with some alcohol.
Your feed rolls, depending on how many pages you have run, may be worn out and need replaced. But that should not occur with less then 40-50 thousand prints on it.
I suspect just some contaminant on the feed rolls.
Let me know please.
Mar 20, 2008 | Xerox Phaser 6120/YN Laser Printer
Loading the paper
Check the paper settings on your word processor. Most probably you picked either a paper type or paper size that is not plain, letter sized paper. That is why the word processor sends the job to the manual tray.
Aug 22, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Xerox Phaser 6110MFP All-In-One Laser Printer Logo
979 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
