Question about Panasonic PT-44LCX65 Television
I have a Panasonic model # PT-44LCX65 TV and have just replaced the lamp, as it was time to do so. A pink dot, that appeared before the old lamp needed replaced, remains on the picture. How is this fixed?
    Problem Solver:
  • 10 Answers
There are a few other threads on this board with the same issue, some say green spots, some say red spots, in my case it was blue/purple spots, but the solution is the same for all of them. Contact Panasonic and tell them that you read online that they are offering a warranty repair for this known "fuzzy spots" issue. They will send out a local repairman who will perform an EEPROM update to one of the computer chips inside of your TV, and viola good as new.
That is what others on this site suggested to me, and I did it and got all repairs covered under warranty by Panasonic even though my TV is 2+ out of the warranty period.
Posted on Feb 09, 2009
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
WHERE IS THE LAMPLOCATED THE TV WENT BLANK LAMP LITE CAME ON
Try website like You Tube.Type in ur tv model and make.You will see a tutoring video how to replaced the projection lamp.
Aug 28, 2010 | Panasonic PT-44LCX65 Television
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
Panasonic PT-44LCX65 - all of a sudden will go blank and ten come back on and then it will go blank again - sometimes this goes on for the whole evening - other times only a few times.
Intermittent loss of picture is most often brought on by an intermittent lamp or ballast board. When you lose the image, look at the rear of the TV for light coming through the ventilation vents. If you don't see any light, its likely the lamp or ballast. If your lamp has more the 3000 hours on it, replace it regardless of whether its the only defective component. It will fail just when something good is on TV!
michtech
Dec 27, 2008 | Panasonic PT-44LCX65 Television
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-44LCX65 Television Logo
268 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
