Question about Maytag Neptune MDE5500AY Electric Dryer
Blown bulb in Maytag Neptune Drying center in tumbler section
I can't find a source to repace the lightbulb in the tumbler section, the light bulb removed has embossed on the base, 10S6 DC/120V -5China.
I've tried internet and local hardware stores, I can find 6 watt bulbs or 10 watt in a 250V version but no 10 watt in a 120v version
  • 51 Answers
1-800-688-9900 OR WWW.MAYTAG.COM, THIS SHOULD HELP YOU OUT.
Posted on Jan 17, 2009
Light inside dryer does not light up.
Your bulb has burnt out. Go to appliancepartspros.com put in your model number, in schematics on left side of page select #5 tumbler, bulb is part #7 cost $5.60. easy to replace, you just have to remove lens cover and replace bulb.
Aug 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Loud noise as the tumbler is drying
Front or rear? Rear is probably center bearing. Fornt is front tub wheel or glide worn out. If noise is in front remove front and inspect.
Jul 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
My lightbulb in my fridge won't go on
Check the tab in the center of he bulb socket. Unplug the frig first and gently pull it up a little. You should be using a 40 watt appliance bulb not a 60. If the tab is not the problem you may need a new switch.
Eric
Apr 29, 2010 | Refrigerators
Need to know what light bulb to use in Maytag Nepture washer
how do I get to the light bulb on the Maytag Neptune front load washer, to change it?
Feb 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag MCE8000AZW Neptune Drying Center. Display
my bottom dryer the light dont come on or when i press start it wont start all i hear is a click...any solutions?
Jan 31, 2010 | Maytag Dryers
Dryer not drying.
I don't know what the noise is but I had the same problem with the drying. I checks several sources because I don't like to replace parts that are not broke. the problem was 2 coils near the pilot light. Each is held on by 1 screw and a wire gets plugged into it. Easy fix and ran fine again. I think the coils are a comment problem because as soon as I told the parts place what kind of dryer I had they told me what I was in for.
Mar 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Maytag neptune dc
I have a Maytag Neptune drying center. The top unit is making a very loud banging noise. How can it be repaired, is this a common problem?
Apr 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Problem with upper cabinent of Maytag Drying Center.
Mine did same thing within warranty. There is a motherboard problem in them that is cause by power surge during an eletrical storm. First try unplugging for 10 minutes and see if it resets. If that doesn't work, you need to have the motherboard replaced that runs the unit.
Repair man took the front off my unit and replaced entire motherboard. He stated that it was a known issue with that motherboard. I have had no problems since my motherboard was replaced 18 months ago.
Dec 02, 2007 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
210 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
