Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Red spinner wont spin. ( Bissell carpet cleaner )
The red spinner that tells me my machine is working properly, is not spinning even when the bucket is full of clean water and the solution container is full. I took the spinner out and cleaned it but still won't work. I don't think my machine works properly because of it
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: My bissell Powerbrush cleaner quit working. The
found it from Tara put online in nov 2008 Thanks this is it
Had the same problem... although I don't have particularly hard water, the heater block corroded just enough to stop most of the flow after about 4 years. Disassemble the handle to get at the heater block (3 pairs of screws/bolts), remove the tubes with needle nose pliers, use a paper clip to knock out the corrosion on the front tube on the heater block, flush with a syringe to get rid of any other bits of corrosion (some extra plastic tubing connected to the back tube of the heater block helps here, and catch the water from the front tube to prevent water in the electronics...), reassemble (avoid disconnecting any wires...) and try it out. Worked for me! I REALLY have to thank the person who suggested this fix! THANKS!!!
I used regular pliers , phillips screwdriver , the pointed end of a compass and a turkey baster full of water to blast it out . You have to improvise . Take your time watch the little rubbers on the heater make sure its not hot . It was just the inlet gets pluged up in the heater . You have to take off the tools then its the bottom set of plastic not the handle . You can test by pushing the plunger at the top . You must take the handle off . Loosen the pieces it just came off for me then snaps back on . This is all it was for me , very simple . I am disabled and did it on a extra old carpet a little at a time over a few hours . For someone healthy its a hour job tops or less . Just be patient . God helps those who help themeslves and asks for patience .
Posted on Mar 28, 2009
  • 29 Answers
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Posted on May 29, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell carpet cleaner manual
Check the dirty tank for proper assembly and how full it is. There is a red float ball in there that might be stuck closed.
Sep 06, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
The unit does not put any watter on the carpet and when I push the triger the red spinner does not move. The tank is full of hot watter
This sounds like your pump brush belt is broken in your Bissell. The belt controls the pump in the machine, as well as the brushes. This would be explain why the solution is not spraying, as well as why the red spinner on the top of the machine is also not spinning.
Here's an extremely helpful video that you can watch on how to replace the belt on your Bissell ProHeat Carpet Cleaner.
If you open up the door and find that your belt is not broken, please just reply using the Clarification Request form here on the Fixya website, and I'll be more then happy to do some advanced diagnosing with you to figure out what the problem is.
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt:
http://www.bissell.com/VideoRating.aspx?id=1555
If this information was helpful to you, help other Fixya users with the same problem find this video by clicking the very helpful four thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris J.
GoVacuum.com
Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
The spinner wont spin
clog, take bottom apart and clean, keep cleaning it theres more in there
Sep 07, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
The water does not shoot out of my bissell proheat shampooer. The red spinner has stopped spinning.
I'm not sure I have the same kind of machine as you because I don't think I have a red spinner. However, I did have the problem of water not shooting out (although the solution was being used up, just not the water). The problem turned out to be the plug underneath the main tank. To find out if this is your problem, lift out the main tank and take it to the sink. Feel underneath for the plug. Push inside of it. Water should squirt out (assuming there is water in your tank). If it doesn't, turn the tank over, unscrew the plug, and push the thing inside until you get it to spring up and down. If it won't do that, you might need a new one. If it springs, screw it back and try your machine again. Mine worked good as new after I did this. Good luck!
Dec 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner brushes won't turn
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell deep cleaner wont release water and cleaner into the flow indicater
do you mean the little red spinning thing?try unscrewing the clear cover , lift the red thing out and check for hair etc.then put it back together. worked for me, hope it helps.
Jul 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat 2x
Check the brush motor, I have had to replace of few of them. If the brushes aren't turning, this could be the problem.
Apr 18, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
318 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
