Question about Dwin TransVision 3 Plus Multimedia Projector
Projector turns on but no light or image from lens.
The bulb looks good, the filiment is not broken. Projector is 4 years old and is used often. There is a blinking red light on the front of the projector and a blinking green light on the front of the processor.
  • Anonymous Mar 24, 2009
    I have the Transvision 4 with the same problem.
    However, the bulb will fire after I pull the power on the unit.
    But I see this as a temp fix rather than a solution...
  • 3 Answers
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Posted on Apr 30, 2009
    Problem Solver:
  • 7 Answers
Replace your bulb. Relampit has bare lamps for allt he Dwin models for cheap. Just because the lamp looks like its ok doesnt always mean its ok.
Posted on Dec 02, 2009
Both of the turn signals do not work. The hazard lights only work in the back. I looked at the fuzes on the passenger side, and they are still good. What can I do to get them to work?
It sounds like you have at least two bulbs out in the front. I suspect that both turn signals did not stop at the same time? Check the front bulbs. Many turn signal bulbs have two filiments; one for parking lights and the other for turn signals. The same filiment is used for turn signals and hazards.
Another possibility is that there is a bad or broken ground wire in the front?
Finally, it could be the turn signal switch.
Apr 05, 2011 | 2000 Buick Century
When I turn on the light, only the headlights get turned on. The rear lights do not turn on. Both signal lights are okay. Hazard lights work. Brake lights work.
visually check condition of bulbs,they are 'dual filiment' bulbs,there are 2 fine wires or 'filiments' that light inside bulb.one may have broken,but not the other[the brake & hazard]
Sep 30, 2009 | 2006 Toyota Sienna
My turn signal flashes really fast I replaced the bulb and it still does it unless you wiggle the handle, The handle its self works properly i.e. clicks into position for left or right turn, is there a...
try your emergency flashers, do they blink at a normal speed? if yes, replace flasher for turn signals.if not check the bulbs on the side that blinks fastest,even if they look good there could be a broken filiment.tap on the bulb, if the filiment moves it's a bad bulb.
Jul 09, 2009 | 1998 Chevrolet Monte Carlo
NEC MultiSync VT540 not turning on - Temperature error
Hi
if the status light is blinking red in 4 sec interval it means that there is something wrong with cooling system. you shold check if there is a thermostat failure or if there are any switches that are not turned on. i suggest you to open the device (using screwdriver) and check if there are any switches broken or damaged.
i had pretty much the same problem (one second interval). i took off the cover and there was a broken switch and i just short-circuit it and now it works
Sorry for my english
Feb 18, 2009 | NEC MultiSync VT540 Multimedia Projector
Sharp Xg-50X projector won't turn on. Replacement light not on.
I pulled the projection bulb and did a continuity check on the filiment. It was open. I ordered a new bulb.
Thanks.
Feb 14, 2009 | Sharp Notevision XG-C50X Multimedia...
Hy, having problem with to conect projektor to the computer Anybody can help
The projector should have a cable similar to the monitor cable that would normally be hooked into the computer. The cables work the same and the one coming from the projector will use the same port as the normal monitor cable. Make sure that there is a good connection on both ends -sometimes one or the other get moved and the connection is lost.
Once the cables are hooked up, the projector should be turned on. Normally the projector will soon begin a startup routine and will cause an image to be shown on the screen. You can focus the image during that time.
After the image goes away you should be able to display whatever you want from your computer's software.
Normal problems in doing this are: leaving the lens cap on the projector, having a burned out bulb - once the power is turned on for the projector, it should cause the bulb to come on. Some models have a power on switch and a display on switch that must both be pushed to make the bulb light up.
Hope this helps.
Dec 26, 2008 | ASK Proxima C160 Multimedia Projector
Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
May 12, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
Dark Area Growing on Right Side of Image
It isnt the lens. There is a crystal asembly that the light is reflected thru after it hits the color wheel. It is 4 pieces of completely mirrored glass glued into a small metal holder. One of those pieces has shifted. To fix it, you can take it out and possibly have a jeweler repair it. It is difficult to take out, but it is doable. Feel free to contact me if you need to. email is (bill @ baerwalde . com) Just remove the spaces.
Oct 10, 2007 | Dell 2200MP Multimedia Projector
Optoma hd72 bulb turning off
This is NOT a bulb problem unless your "lamp" LED is lit, which you say it is not. Many people have reported this problem with the Optoma 72. You can send it in for warranty service (it has a 2-year warranty) to get the lamp controller chip replaced, but the problem may recur. Optoma does not appear to have a permanent solution to this problem. My projector has broken exactly like yours TWICE in a year. I haven't even needed to replace the original bulb yet. :(
Nov 05, 2006 | Optoma HD72 Multimedia Projector
Dwin TransVision 3 Plus Multimedia Projector Logo
555 people viewed this question
Top Dwin Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dwin Office Equipment and Supply Expert? Answer questions, earn points and help others
