My car radio doesn't work couse the antenna, where can i found the fuse
SOURCE: When I start or shut
there is a geared strap inside of a antenna that makes the unit rise and drop,, they strip out,, some can be changed as in Toyota's I'm not positive that Buick has that switch out, you'd have to pull the unit to be sure , you could also check the local junk yards to get a complete replacement for pretty cheap, just be sure and find a 12 volt power source to check it before you purchase it, they have batteries there I'm sure !! Good Luck
SOURCE: REMOTE DOOR AND TRUNK LOCKS DON'T WORK,
Did the problem come on suddenly or was some previous action or work done......
Wrong amp fuse or maybe you have a loose wire or a short somewherecausing the fuse to burn out?
