Question about Acer (ACERMOTHERBOARD)
Lights on but no one home...
The power indicator in the front turns on but when I go to boot the computer nothing happens. What can cause this and what can I do to fix it?
  • 705 Answers
This could be one of many things: First off if the set up is new and you just put it all together try removing all the IDE/SATA cables and see if that helps. If the machine then boots you know one of those devices is faulty or setup wrong. If that does not help, remove the RAM modules and try again - this may invoke a different error as the board may not want to boot without any RAM but you should notice a change. If no change then it could be the CPU or power supply unit (PSU) The MOST likely problem is that the PSU has given up or is not producing enough juice or is producing too high a voltage. The only way to check this effectively is to try a different PSU. I had a customer who brough me a machine which had stopped booting. He was told by a "friend" the CPU & mainboard had failed so he bought a new CPU and mainboard. The machine still did not boot and in fact the power supply was producing to high a voltage and had fried the mainboard and CPU. Then it fried the second CPU and mainboard he put in. Expensive mistake... so make sure you replace the power supply (or have it fully tested buy an expert) BEFORE you add any new parts to the set up.
Posted on Jun 19, 2007
SOURCE:
Dell Latitude 6500- the power button lights up when plugged in and keyboard will light up but nothing else happens. The machine has a weak battery so I operate it without the battery plugged in.
First of all, you need the battery for a lot of the computer functions to operate. The wrong time and date can really cause problems for your computer. Replace the battery. Have your motherboard checked. Also, run setup when your computer starts to boot to make sure your system settings are correct.
Sep 15, 2014 | Dell LATITUDE Computers & Internet
Sharp flatscreen tv does not turn on
If the front panel indicator lights, power is getting to your TV. If nothing happens when you turn it on, it is likely that the internal power supply has failed
Jan 04, 2013 | Sharp 75006932 LK315T3LZ41C 32in LCD Panel
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
No signal displayed
hi,check the CPU of your computer if it is booting properly.you can try to push the caps lock of the key board pressing the keyboard once the LED light indicator lights up then press again the light will turn off .This means that the CPU boots up and functioning properly.Check the data cable connecting the CPU and the monitor there must be a broken line there you can replace the cable or you can re insert the cable a loose connection can cause the problem.IF all are good and still same problem try to re insert the video card from the main board make sure to turn of the power before removing the video card...try this solution and post back if nothing happens after doing these solutions..good luck!
Apr 02, 2012 | Intel Computers & Internet
Hi, I've had my Acer aspire laptop for a few years now, but I haven't used it for over a year (Because I got a desktop). So when I've come to turn it on today, It won't work. The screen...
Start with pulling the battery and power, then hold the power button in for about 30-40 seconds. Then plug the power back in (still no battery). Try to power up the computer. If it boots, shut it down and put the battery in and try again. If it boots the issue was cleared. If it boots with the power cord but not with the battery added, you have a battery issue.
Hope this helps
Sep 01, 2011 | Computers & Internet
Acer aspire m3201 wont boot up
There are numerous issues that could cause this but if absolutely nothing happens, no lights, no fans, nothing then check the power supply. Use a simple voltage tester to see if you have any voltage on the connectors going to the hard drive and cd/dvd drives. If not this is a pretty easy and relatively inexpensive fix. You can e-mail me at [email protected] for more help.
Jan 02, 2010 | Acer Aspire M3201 Phenom X3 8650 PC...
Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
May 21, 2009 | Acer Aspire 5100 Notebook
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
85 people viewed this question
Ekse
Alun Cox
