Question about Dell Latitude D600 Notebook
I have to hit f1 to start pc need boot up files thanks
    Sergeant:
    Champion:
  • 256 Answers
Check time and date in bios or hdd problem smart may be bad, if yes replace hdd....
Posted on Jan 16, 2009
Ever time I start my computer I have to Ihit F1
go into bios and change your boot up start from CD/DVD to hard drive then you wont get f1-f2 error.
Jan 21, 2014 | Dell XPS Computers & Internet
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
Hi, This is the message my pc displays when I try to install an operating system: Windows failed to start. A recent hardcore or sofware change might be the cause. Tofix the problem: 1 insert your...
First of all, you have to change the boot sequence to CD/DVD drive on BIOS. so go restar pc and hit f1 or f2 then go to boot options to change it. hit f10 to save and exit. restart again and put the recovery disc. when it says press any key just keep on hitting enter until it says window is loading files: follow this webiste : http://www.windowsreinstall.com/
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. God bless. Bye for now.
Jul 18, 2011 | HP Compaq d530 SFF PC Desktop
Cannot get the computer to boot up
it may be a missing or crupted start file, your best bet it to perform a hdd recovery by turning your computer on then when the loading screen appears and gives the option of hitting f1 f2 f3 and so on, you need to hit f8 and follow the steps on the screen. hoped this helped
May 12, 2011 | MSI Wind Top AE2220-236US - P T4500 .1 GHz...
My computer starts on black screen... drive 1 not found: serial ATA, SATA-2.. strike the F1 to continue, F2 to run.. if i press F1 it says NTLDR is missing what di i do? I have the operating sys. disk..
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Feb 03, 2011 | Dell Dimension E310 PC Desktop
Heloo sir i have a problem with my dell 170l when i start it it shows ''strike F1 to continue, F2 to run the setup utility'' when i click f1 it show ''f1 to retry boot,f2 for setup utility'' plz help me...
Hit F2,look in setup to see if the hard drive is recognized and check that the date and time are correct.
Then hit esc key. it will ask if you want to save changes, click yes. It should boot and probably ask you to hit F1 or F2 again., unless there is a problem with the CMOS battery, which may need to be replaced.
If you hit F1 to continue, it will boot, but your time and date will be off.
Dec 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I have a Gateway 507 GR Windows XP Home Edition. Windows does not load/Boot, Error message "Not found or corupt. I can hit I think it is F-2 or F-12 (I forget) and go to the BIOS settings, and try and...
to go to bios setting either u can hit F2 or F1 key. then u change the boot priority. set it to cd-rom device.
after that u can boot from any bootable cd.
for your operating system problem, boot from the xp bootable cd after setting boot priority, and then repair or reinstall your operating system. some files might have been corrupted.
Mar 01, 2010 | Gateway 507GR PC Desktop
Problem starting my computer
sound like the internal bettery need to be replace.
do yo have dula boot machine? if not, then change the internal bettery.
Mar 17, 2009 | Microsoft Windows 98 for PC
Boot problems,have to hit F1 to boot to windows
Can you get it to go into windows at all?
Did you actually change the CPU?
When it says to hit F1, keep hitting it repeatedly, you will kow it acepted it when you hear a little beep from the P.C. Case
then it should go into bios. if not, then it may not be recongnizing the keyboard.
typically this issue occures because the internal clock is off do to apower shortage or the Bios battery has dies. Its a little watch battery on the system board. If you can get into windows, check the date and time, set it and it should sync the bios clock.
Let me know how it goes.
Feb 04, 2009 | Dell Dimension 3100 PC Desktop
How to change the boot option in IBM 6578-PBU desktop
I searched for hours for a solution to this. Here it is:
1). Restart your computer, NOT using ctrl - alt - del
2). Press F1 when guided to.
3). When you get into the config menu, select Start Options, then hit enter twice.
There are all the options you need! Cool, huh?
Aug 26, 2007 | IBM NetVista A40 PC Desktop
Dell Latitude D600 Notebook Logo
42 people viewed this question
Alun Cox
