Question about Fujitsu AMILO Pro V1000 Notebook
Sound My sound keeps going off how do I switch it on?
    President:
  • 2,961 Answers
Assuming your'e not accidently muting it, it could be a sound driver corrupt, so go to my computer icon, right click>properties>hardware tab>device manager and look down list to sound, video and game controllers and click on the '+' sign. Look down the list for either realtek ac97 audio, or ac97 audio controller and right click on it and select uninstall. Restart notebook and the driver will automatically re install and should be ok,unless you have speaker trouble.
Posted on Jun 19, 2007
My break lights will not go off?
Check switch above brake pedal to insure it is fully depressed when pedal is up. If it is, unplug switch and if lights go off replace switch.
Jul 21, 2016 | 1995 Honda Civic del sol
Why does indicator light keep flashing,switch in nutral 1976 mini moke
Sounds like you need to replace the indicator stalk, first remove it, clean it up with wd40 clean electric connections & see if it works
Mar 07, 2015 | Mini Cars & Trucks
Chime keeps going off 2005 f-150 4-4
The chime will keep going off if it doesn't sense if the driver's seat belt is not clicked in. It may also be a bad door switch that shorts while driving down the road.
Mar 25, 2014 | 2005 Ford F-150 SuperCab
The rear door automatic lock keeps going on and off and the bell keeps chiming by itself especially in the rain and when I hit a bump in the road, how can I stop this?
this is usually an issue with the door switch, check the door for correct adjustment, if ok test out the door switch
Jun 15, 2012 | 2000 Dodge Caravan
I had similar problems: new batterry but periodically go thru all the switches to start (kickstand up, red switch to on) dash lights up but when I go to start nothing no a sound?? only does periodically...
Sounds like a safety switch .I would start with kickstand.there is a switch on kickstand make sure wire is connected to switch and push switch by hand to activate.Could be hung up or gone bad.Try also lubricating kill switch on handle bars they are known for not making contact and will keep engine from starting.
Feb 10, 2011 | 2003 Suzuki AN 650 Burgman
DRYER HUMS WHEN CNTROL KNOB IS PRESSED & MOVES SLIGHTLY..IF HELD IN TOO LONG IT BKICKS BREAKER. MODEL#HYE3658AYW
Greetings,
This sounds like the motor is bad, or going bad...I would have someone help you try and start it....open the door and hold the door switch in and keep holding the door switch while pushing the knob to start it and at the same time....have someone try and turn the inside drum usually, counterclockwise and see if it takes off....if it does...let go of the start switch up on console(timer),
but keep holding in on the door switch to let it run for awhile...you can shut the door real fast and it should keep running... if none of this works and it still will not start and just hum...the motor is bad
Dec 08, 2010 | Maytag Dryers
Driver door ajar alarm keeps going on and off as I am driving and the door locks keep clicking on and off. This only happened occasionally, I sprayed WD-40 in lock area and it stopped for a few weeks. Now,...
This sounds like a bad door switch,if you replace the switch i think it will solve all these problems,the switch is locted on the latch asm,remove the door panel,mark and remove the linkage,then unplug connectors,then remove screws holding latch,remove the latch and then remove switch,it comes out by twisting,and then pull up,to install new one,line up slots push in and turn to lock in place,good luck.
May 03, 2010 | 2003 Chevrolet Avalanche
I have no sound with any movies on my blu-ray player
go to sound settings and make sure you got the settings correctly there is a lot of different settings if somebody move the settings accidentally then they have to be reset how well here is how turn the main power switch off now put your finger in the on/off switch in front of the console now turn the main power switch on keep your finger in the on switch you will heard a bip this bip is when the system turns on keep your finger there until you heard a second bip then take your finger off now your video and audio settings have been reset
Apr 24, 2009 | Sony Playstation 3 (PS3) Console
2005 hyundai elantra alarm keep going off
check door switches,trunk switch,hood switch sounds like dirty contact after you set alarm if any of these contacts lose contanuity your alarm will go off alarm system thinks doors,hood,trunk has been opened
Feb 07, 2009 | 2000 Hyundai Elantra
Audi a3 1.9 tdi alarm keeps going off
this sounds like a faulty 'boot' switch. Many of the older models had issues with picky switches
Dec 17, 2008 | 2007 Audi A3
Fujitsu AMILO Pro V1000 Notebook Logo
139 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
