Question about Sony KP-65WS500 65" Rear Projection Television
Turns green and shuts off
At first, the only colors that we could see on the pic were red and blue so we opend the back and noticed that the green lamp was out. then a day latter the tv would turn green and shut off, and will not stay on. any suggestions????
  • canezj Jan 24, 2009
    I have this same problem. My television will flash green, then turn itself off. I don't want to buy a new television.
I had an electrician come over. He pulled out the bulb that was dead (for me it was the color that was flashing before it would turn off) and now I have a blue and green TV with no red. He said that the only way to fix it is to replace the red lamp with a new one.
Posted on Mar 01, 2009
The grey in my relaxed brown hair occasionally turns a greenish color I use adore semi permanent, dark chocolate any idea how to avoid this?
Your hair is turning green because your missing red when you color your hair. Gray is uncolored hair and to get to a dark chocolate brown you need to add a little red to the color to make up for this. You don't need to strip it out.
Have you heard of people using purple shampoo to neutralize the yellow tones of their blonde? Red will neutralize the green tones, so adding a little red to your color will do this for you.
Mar 09, 2014 | Adore LVT Semi Permanent Hair Color 112...
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
Hi,,i only see two colors on my tv screen,blue and white,,waht should i do..please help me
there are three primary colors from your TV's chroma circuit, red green and blue..
you'll notice it when you open your back cover of your television set, the wire colored red, green and blue.. you better leave it to the expert technician to prevent severe damage
Sep 15, 2011 | Sharp 27F543 TV
No this didnt help at all, my samsung tv still turns out black and white, im not using a HDM1 cable im just trying to get the normal tv to work, i have noticed the tv only has the green, blue, and red...
As long as you can see that those ports on the back of you TV say input and not output then your compsit color code is White=audio, Red=audio, Yellow=video. It should work the green, blue, and red is just another type of component use. Good Luck!
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
How can you tell if one of the bulbs is burnt?
That color won't work good. On RPTVs, Red bad = blue-green pic; Green bad = purple pic; blue bad = yellow pic.
May 02, 2010 | RCA HD52W58 52" TV
TV Turns Off, Color is Turning Technicolor Blue-Green
sounds like the tube is going on the set best thing to do is consider buying a new tv or take to your local tv repair shop and they should be able to sort it for ya :D
Mar 10, 2009 | Daewoo DTQ-27U4SC 27" TV
Hi i need your help please
When you adjsuted for the blue you were actually adjusting the voltages to the CRTs (lamps) which in turn shut them down. You will need to turn each one of the dials up agin untill your tubes stay lit, then the coolant in the green and blue CRTs will need to be changed as the green evidently is contaminated thereby making the blue dominant. But when you turn down the G2 controls your actually turning down the High voltage to the picture tubes thats why they dropped out on you.
Aug 24, 2008 | Televison & Video
Hitachi Ultravision50vf820
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 22, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
127 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
