Question about Swintec 7040 Typewriter
MY SWINTEC 7040 WON'T RELEASE MARGIN.
I KNOW WHERE THE MARGIN RELEASE KEY IS BUT IT'S STILL NOT RELEASING IT AND IT ACTS LIKE IT IS STUCK. DO I NEED A NEW TYPEWRITER? AND ALSO IF I TURN IT OFF AND BACK ON IT WILL ACT BETTER FOR LIKE ONE TIME THEN GETS STUCK AGAIN!
  • 215 Answers
Chances are, you need to clean and put a light oil on the silver rod that the carriage moves on. it will get dry and you will lose your left margins. pretty common on these model and others.
good luck,
razors
Posted on Feb 27, 2009
  • Swintec Master
  • 3,594 Answers
Return to the L. mar. press and release the mar. rel. key, backspace to the place you want the margin press L. mar. key.
DickyO
Posted on Jan 19, 2009
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
How to reset the swintec 7040 back to factory settings
Turn off, hold down on the MR (margin release key) and turn on, machine will print some numbers and then print lines of types, let it print a couple lines then turn off and turn on.
Oct 23, 2013 | Swintec 7040 NEW Electronic Business...
What do I press to set my left and right margin on the swintec typewriter 7040
Go to the margin you wish to change, PRESS BUT DON'T HOLD the MAR REL key space or backspace to the desired location press L. or R. mar key.
DickyO
Feb 18, 2012 | Swintec 7040 Typewriter
How do I unlock right margin on a Swintec 7040 typewrite?
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
razors
Nov 03, 2011 | Swintec 7040 Typewriter
I cant release the margin on the right
Go to the margin press but don't hold the mar rel key and you should be able to space to the desired location then press the R. margin key.
DickyO
Oct 19, 2011 | Swintec 7040 Typewriter
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
Swintec 640 margin release
If it is the left margin, you touch the carriage return button to find the current position of the left margin, then touch the mar release button and backspace to the new left margin location, then depress the left mar key. You should here a beep. You are done.
Jul 22, 2009 | Swintec 7040 Typewriter
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
Feb 02, 2009 | Swintec 7040 Typewriter
Margin release
Turn the typewriter on press the return key. If you want the margin to the left of were it is set press the MAR. key ( margin relace) press the back space key to the desired spot. press the L margin key. Your left hand margin is now set. Space to the right to where you need your Right hand margin to bo. If stops before you want it to press the MAR. key press the space bar till the drsierd place press the R MAR key.
Jan 29, 2009 | Swintec 7040 Typewriter
Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Aug 01, 2008 | Swintec 7040 Typewriter
Swintec 7040 Typewriter Logo
223 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
