After charging go gear- ok to disconnect screen is locked up
After chargin go gear the ok to disconnect screen is locked up tried several things to get it working but nothing just the same screen saying ok to disconnect
the reset thingy worked but what is the Philips Device Manager? cuz when i go to playlist it won't show my playlists it just says new playlist or it has a list of repeated "delete a playlist" options. It gives me 63517 "delete a playlist" options and none of my playlists show up. the reset thingy worked but what is the Philips Device Manager? cuz when i go to playlist it won't show my playlists it just says new playlist or it has a list of repeated "delete a playlist" options. It gives me 63517 "delete a playlist" options and none of my playlists show up.
AnonymousMar 02, 2009
after chargin go gear the ok to disconnect screen is locked up tried several things to get it working but nothing just the same screen saying ok to disconnectafter chargin go gear the ok to disconnect screen is locked up tried several things to get it working but nothing just the same screen saying ok to disconnect
AnonymousMar 03, 2009
after chargin go gear the ok to disconnect screen is locked up tried several things to get it working but nothing just the same screen saying ok to disconnect after chargin go gear the ok to disconnect screen is locked up tried several things to get it working but nothing just the same screen saying ok to disconnect
You can't post conmments that contain an email address.
I have the same problem, did you solve it? When I connect my go gear to the pc I can use it and seems to be fully charged, but when I disconnect the USB the device turns off. I tried to press the reset button but it has no effect. Any suggest? Thanks
Mine worked fine wit Samsung Galaxy S2 but today will not charge hmmm sud happin to me was chargin fine with a 4,2 volt charger does anyone no.wot volt it shud be cos I cant find anythin about this v-com or the supplier
Try charging the phone until it has finished charging.connect the charger and charge for 2.5 hours. The battery icon on the screen may not appear for 30 mins.
You can also go to a dealers and ask to try a new battery, or and a different charger. If none of the above work ring your network supplier and ask for a replacement phone.
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Try another charger. I broke the plastic that locked into the phone on my car charger and had problems charging. The phone is very finicky about the contacts. Had to replace charger.
