Question about Motorola Walkie Talkie 2-Way Radio
Ive only had my walkie talkies for 1 year. I only use them for hunting. One of them seems to not take a charge for very long time. Can I replace the rechargeable batteries with regular lithium batteries.
  • m3odq May 11, 2010
    Whats the radio?
    What type of battery does it have at the minuite?
    Are they AA or similar? Or does it have a battery pack?
    Let us know and we'll try our best!
    M3ODQ
  • eradiostore
    eradiostore May 11, 2010
    What kind of radio do you have? Some will accept Li-Ion and some will not.
  • 3 Answers
Replace the battery with the same type that is in the radio. It will last for another year.
Posted on Feb 06, 2009
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
I was hunting and lost the back plate of my Fr50 Walkie Talkie and I would like to buy a replacement, can you help me...Thanks, Fred Tripp
Hi Fred,
Take your radio to your local Radioshack or similar store and the folk there should be able to assist you in the hunt of the part you require.
Hopefully this is helpful to you.
Cheers,
Peter
Dec 09, 2012 | Motorola Talkabout FR50 (14 Channels)...
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
Walkie talkie batteries don't last
What you have been using are consumer grade walkie talkies. The rechargeable battery packs in them should last a full business day, unless you are in a high use area. This being said, it is also possible you might need to replace the rechargeable battery pack as they usually have just a one year life expectancy. As they start to fail they will go less and less time in a day.
To answer your question about a radio which will go a full business day, any of the business division Motorola handheld radios would work. Radios such as the CP110, BPR40, CP185, and CP200 are all make to go a full day and sometimes more. Their battery packs depending on chemistry would also need to be replaced every 18-24 months.
Best regards.
May 14, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
The Batteries that Motorola uses will die after a while mainly because people leave them on the charger all of the time. But there is a way to refresh them. You let the battery die completely, then you charge it up for about 12 hours. Then you let the battery die completely. Do this a couple of times and the batteries will last long.
Also, Motorola use to make a battery refresher (or did when I worked there.) It will charge and drain the battery automatically. It will even give you a fault if the battery is completely dead. For the HT1000 (for example) it would be the WPPN4065BR.
For future reference, don't constantly charge a battery. Only have it on the charger when the battery is actually dead or very low. This will increase battery life.
Mar 25, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Microtalks don't seem to charge, even charged many hours
When you say they worked fine for a long time, do you mean a long time as in "hours", or for many months or years? If hours, then remove the batteries and be sure they are in correctly and plug the charger into a different electrical outlet. If the radios have not been used for many months or longer, you probably need to replace the rechargeable battery.
Feb 06, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Radio Communications Logo
111 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
