Question about Samsung 906BW LCD Monitor
Black lettering has red or green highlights
Just got a Samsung 906BW 19" monitor for Father's Day. Only problem is that some of the black lettering has a red or green tinge to it. My graphics card is a 128MB DDR Nvidia GE Force FX 5200. My computer is a Dell 4600 Pent.4 2.4 GHZ and 512MB Ram. How can I get rid of this?
  • 2 more comments
  • John Lasher Jun 19, 2007
    Thanks for the suggestion. I had already done the 'clear type' thing. It made the lettering clearer but didn't help with the color problem.
    Sorry you are right I should of used the "thanks for trying" button.
    What are your other suggestions?
    Thanks for trying. Did both resets but still got the colored tinge to the letters. Got anything else?
    Yup, have done both of those things.
    President:
  • Samsung Master
  • 1,314 Answers
Try turning on cleartype if you are using Windows XP. 1. Right click on the desktop and select 'Properties' 2. Select the 'Appearance' tab and press the 'Effects?' button 3. Check the box for 'Use the following method to smooth edges of screen fonts', then select 'ClearType' in the dropdown list 4. Close the Effects dialog by clicking 'OK' and click 'Apply' to complete the process
Posted on Jun 19, 2007
  • 2 more comments
  • Kevin Shafer
    Kevin Shafer Jun 19, 2007
    So you rated it not helpful instead of thanks for trying because you didn't include that information? How about waiting for more information as I have three other solutions here for you to try.
  • Kevin Shafer
    Try doing a factory reset if you haven't already done so:
    Resetting Current Samsung Monitors
    To reset most current Samsung monitors to their factory settings, follow these steps:
    1. Press the Menu button on the monitor. The OSD menu appears.
    2. Press the Adjust (up or down arrow) button on the monitor to change the menu window until you see the window containing Autosource, Image Reset, and Color Reset.
    3. Press the Select button on the monitor to select the this window.
    4. Press the Adjust button to highlight either Image Reset or Color Reset.
    5. Press the Select button. The Image Reset or Color Reset window appears.
    6. Press the Brightness/Adjust button on your monitor. Yes is highlighted.
    Note: As soon as you select Yes, the monitor resets to the factory presets.
    7. Press the Menu button on the monitor three times to exit.
    Note: You must perform both Image Reset and Color Reset to reset your monitor completely to factory presets.
  • Kevin Shafer
    Try the instructions located here:
    http://erms.samsungusa.com/customer/sea/...
    This will set the optimal resolution and refresh rates for your monitor. Also make sure that you have the latest graphics driver for your video card located here:
    http://www.nvidia.com/object/winxp_2k_93...
  • Kevin Shafer
    Well it appears as that is all I have for you. I guess the next step would be to contact Samsung support or take the monitor back and exchange it. If the exchanged monitor does the same thing, then contact Samsung support and see what they have to say.
Samsung 906BW failure. Screen is black; Power indicator blue and flashing. Worked fine the day before, Alt monitor works on same desktop (Win Vista Home Premium on Gateway DX4200-09/AMD Phenom 9150e...
Try it on another PC first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 30, 2010 | Samsung 906BW LCD Monitor
Purchased the Samsung SMT-190DN a year ago and came into our business and our screen is black. What can we do to get it fixed? Also, once fixed, can we view more than just 7 days of memory?
This seems to happen to a lot of then Either the Inverter Board is bad or the power supply board is bad. Good luck getting it fixed. Samsung seems not to even think they made them.
I emailed all over trying to get mine fixed with no luck. Do you mean the 7 day of recording,this will record til the day you turned it off YES!! even with the screen black it records DO THIS!!!
First... On the back of the monitor look for VIDEO OUT Its down near the Camera wires
Do you have a set of VIDEO and AUDIO cables there red, white,&yellow????
Get a 19'' tv with video and audio INPUTs NOW!! with the RED cable hook it to the Monitor Video out and the other red end to the tv Video in Just the RED ONE don't worry about white or yellow.
NOW turn the Security Monitor ON , NOW the TV let them warm up The tv must be in Video1 or
Video 2 ---NOW YOU SHOULD SEE THE CAMERA's or the screen POINT the remote at the monitor to do things like menu, search. Sorry I'm not to good at explaining things THIS Should work GOOD LUCK
Jul 26, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
Samsung 906BW monitor wont turn on, power switch
rommelnmariv, 906BW will need to use warranty or if you are not a tech with soldering equiptment then unit will need to visit a tech to be evaluated for it's Black screen or It's Blank n Black screen problem. Read my older fixya responses (late 2009) and follow all links. Yes, some of these can be fixed-up (DIY) for under $10. Read my fixya profile for about an hour !!! Maybe you will ask your 906BW " What Brand of capacitors do you have inside you??" Bye for now. 12fixlouie
Mar 27, 2010 | Samsung 906BW LCD Monitor
Samsung SynchMaster906bw. Screen is black. Power button flashes.
This is 2007 monitor, time to look for bad caps in the power supply first, the problem acn also be in the inverter circuits, or bad lamps. Open it up and post back so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 22, 2010 | Samsung 906BW LCD Monitor
My wife's mom bought us a desk top p.c with this samsung 906bw
Well, seems like the CPU is the source of the problems, not the LCD Monitor.
The simple way to check it is by remove the cable from CPU unit, see for any sign such us color pattern moving or any sign.
the other way is, try using other CPU or Laptop, then connect it to the LCD Monitor.If it works, then you need to repair your CPU.
Hope it's working
Will not turn on at all
IF UNDER WARRANTY (3YEARS)
GET IT REPLACED/REPAIRED
IF NOT
THEN SEE THE SERVICE MANUAL FROM ESERVICEINFO.COM
GIVE ME ALL THUMBS AND VOTE ME
HAVE A NICE DAY
Jan 28, 2010 | Samsung 906BW LCD Monitor
My samsung monitor 906BW is blurry
look through the menus and see if you can find an option in there saying "sharpness" increase and decrease it and see if it makes any difference
Mar 25, 2009 | Samsung 906BW LCD Monitor
Power Supply for Samsung 906BW
Of course there is - but are you willing to pay for it? Check for it on google and see if the expense is warranted.
Sep 23, 2017 | Samsung 906BW LCD Monitor
Color in text
The monitor convergance adjustment is out . Is it a LCD or CRT
Jan 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 906BW LCD Monitor Logo
127 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
