Question about General Electric WCVH6800J Front Load Washer
WCVH6800J GE Front loader timer keeps resetting
A new machine-the timer initially says the load will take 58 minutes but keeps resetting around the 30 min mark and the 10 minute mark- the load takes 2 hours
  • 1 more comment
  • Anonymous Mar 11, 2009
    It an all electric timer. Problem is the unit is decieding it out of balance and constantly trying to rebalance it. I bet the clothes are wet when you take them out too.
  • dcbtx May 04, 2009
    ..05.04.09 The problem is that the washer cannot balance a load. I was told by warranty repair person that GE tells them to advise customers to load only like items, eg. towels, or nylon underwear, or sheets, but not to mix loads and to load 3/4 full. (I assume because of the balance problem.) A friend had the same washer and had the same problem. The balance problem causes washer to "walk" and "wobble" and prevents fast spin so that the clothes are never "spun dry" before placing in the dryer. I have spent as much as 4 hours to complete a stain wash cycle that should only take 2 hours 56minutes. Plus, I had to babysit the washer to maker sure it did not "walk" into my water hoses and burst them. I don't believe this problem is fixable in this unit.
    I am now beginning the process to get satisfaction through replacement or upgrade, dcb texas
    Normal
    0
    upgrade, dcbtx
    President:
  • 373 Answers
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
Posted on Jan 16, 2009
Why does my LG WM1814CW's timer get stuck during cycles, A 28 Min cycle will take 45 Min.
It could likely be that this is during a fill portion of the wash or rinse cycle, and the water inlet is restricted not allowed the full flow into the tub. If this is the case, check both ends of the hose connections for a plugged / restricted filter. run some water into a container with hose off to purge any additional minerals from the intake.
Jun 16, 2014 | LG WM1814CW Front Load Washer
AUTOMATIC HEAT SETTINGS NOT WORKING PROPERLY
lg's have a dry sensor that senses the wetness of the load they are not that reliable.. and will shut down the machine does it work on manual timer? meaning set it on high for 30 minutes.. it will probably run the 30 minutes... I have had this issue with my lg and so I just use the manual settings cheaper than having a 300$ service call. Its a problem with the dry sensor on the lining of the drum...
Dec 09, 2013 | LG DLE5977 Electric Dryer
GE basic timer model 15131 manual missing
It's a little backward from what I was thinking. The "Stops" haveto be UP for the timer to be OFF. When you want the timer toturn an object ON you push the "Stops" DOWN.Thanks to geno_3245 for posting the initial information.
Sep 25, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Program a timer
You posted under Paragon 2606 Panel-mount countdown timer.
If this is not your timer, add a comment.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
2600 series is mechanical interval timer.
26006-00 can handle 10 amp loads.
Interval timer is a countdown timer that keeps Load turned on for set amount of time.
You set the time by rotating dial
To start timer, Rotate dial from 1 minute to 30 minute.
Rotating dial turns on Load and begins countdown.
Timer turns OFF Load after set amount of time expires.
Nov 26, 2010 | Electric Paragon 2606-00 Timer
When the timer gets down to 1 minute left and the machine is on the spin cycle, it takes another 10-20 minutes to finish the cycle. The total 40 min. cycle takes over an hour to complete. Does anyone know...
The timer is only an estimate. pull the botttom cover of the front of the machine. There is a cleanout on the water pump, if its clogged it could be the cause of your timer taking so long
Jun 11, 2009 | Whirlpool GHW9100L Front Load Washer
Wash cycle taking way too long, like 90+ minutes
You timer is bad and needs to be replaced. Your problem is a common error and is something a lot of people on here run into. You can go to repairclinic.com and get this looked at
May 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing takes longer
Reset the options to clear out the current settings.
Mar 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Unit goes through any cycle in mere minutes
it could be drys on the modul its not the prgramer you will have to get your local applince second hand shop to take a look tell them it should take them 10 to 15 mins if there any good
Dec 14, 2007 | Frigidaire GLTF1670A Front Load Washer
General Electric WCVH6800J Front Load Washer Logo
1,044 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Oloyede Monsuru
geapptech
Are you a General Washing Machine Expert? Answer questions, earn points and help others
