At power on no high voltage sound only the initial sound of the degaussing system
SOURCE: is my tv dead?
no not at all , may be lot or h.o. transitror ar circuit dry solder, if any problem led red indicator blinks continuesly.. please chek all h.o section...and smps...
SOURCE: no sound and picture or video
please help !!!! is it an expensive fix ? yes it is too expensive to fix it better to buy new one. as even you fix it , it will always give you problem. good luck
SOURCE: blinking screen
ON THE 36 INCH SONY THE PROBLEM LIES ON THE PICTURE TUBE.THERE IS A LEAKAGE EITHER HEATER TO CATHODE OR G1 INSIDE THE CRT.THE ONLY WAY TO FIX IT IS REPLACE THE CRT OR HAVE THE CRT GUNS CLEANED THRU PICTURE TUBE TESTER/RESTORER/REJUVINATOR AVAILABLE ONLY FROM TV TECHNICIANS.GOOD LUCK.4TUNE.
SOURCE: SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
SOURCE: TV does not turn on
Try to remove the vertical IC sometimes it become Shorted causing the B+ to drop. after removing try to switch on back check the B+ if ok and the LED not blinking then change the vertical IC.
